Introduction
The Macintosh 165c can take any any compatible RAM chip up to 4 MB. RAM can be upgraded to a maximum of 14 MB through the PSRAM chip.
Pièces
Aucune pièce nécessaire.
Orient the computer so the battery is facing you.
  • Orient the computer so the battery is facing you.
  • Slide the gray plastic battery cover to the right.
Ajouter un commentaire
Pull the battery toward yourself until it is fully detached.
  • Pull the battery toward yourself until it is fully detached.
Orient the computer right side up with the rear facing you.
  • Orient the computer right side up with the rear facing you.
  • Open the Input/Output (I/O) door.
Carefully bend the door into an arch until one of the pins releases from its slot.
  • Carefully bend the door into an arch until one of the pins releases from its slot.
  • Once one of the pins is free, remove the I/O door from the computer.
Orient the computer with the bottom facing up and rear facing you. You should be able to read the Macintosh label in this position.
  • Orient the computer with the bottom facing up and rear facing you. You should be able to read the Macintosh label in this position.
Use a T8 torx screwdriver to remove the 6.8mm long screw above and to the right of the modem jack.
  • Use a T8 torx screwdriver to remove the 6.8mm long screw above and to the right of the modem jack.
  • Twist counter clockwise to remove the screw.
Use a T10 torx screwdriver to remove the four, 18mm long screws from the lower case.
  • Use a T10 torx screwdriver to remove the four, 18mm long screws from the lower case.
Place your hands on the lower case, just above the I/O panel, and slowly lift the lower case a few inches above the main body of the computer. Release the large, gray interconnect ribbon cable just behind the I/O panel.
  • Place your hands on the lower case, just above the I/O panel, and slowly lift the lower case a few inches above the main body of the computer.
  • Release the large, gray interconnect ribbon cable just behind the I/O panel.
  • Caution: Lower case cannot be fully removed until two plastic clips in the front corners are released. See the following step for details.
Place your thumb on the upper case, inside the empty battery slot, and your index finger near your thumb on the left side of the lower case. Pinch your thumb and index finger towards each other to release the clip. Without releasing pressure on the pinch grip, use your index finger to push the lower case upwards.
  • Place your thumb on the upper case, inside the empty battery slot, and your index finger near your thumb on the left side of the lower case.
  • Pinch your thumb and index finger towards each other to release the clip. Without releasing pressure on the pinch grip, use your index finger to push the lower case upwards.
  • Lift the lower case to remove it.
Locate and lift ram card directly up until connector releases. Move the card back and forth gently if the connector does not release immediately.
  • Locate and lift ram card directly up until connector releases.
  • Move the card back and forth gently if the connector does not release immediately.
Locate and lift the PSRAM expansion card vertically until connector releases. If the PSRAM expansion card is difficult to remove, gently jostle it back and forth as you lift up.
  • Locate and lift the PSRAM expansion card vertically until connector releases.
  • If the PSRAM expansion card is difficult to remove, gently jostle it back and forth as you lift up.
  • The PSRAM expansion card is an optional component, and may not be included in all devices.
Adam
Membre depuis le 12/10/2011
1 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 6-3, Regan Fall 2011 Membre de l'équipe Cal Poly, Team 6-3, Regan Fall 2011
CPSU-REGAN-F11S6G3
4 membres
12 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 900
