Pièces
Aucune pièce nécessaire.
The battery compartment is located in the front-right side of the laptop.
  • The battery compartment is located in the front-right side of the laptop.
Ajouter un commentaire
To insert the battery, gently slide it into the compartment until it clicks in place.
  • To insert the battery, gently slide it into the compartment until it clicks in place.
  • To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
  • With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
Carefully pull up on the front of the keyboard to pop it out from the case. Then slide the back out so the keyboard becomes nearly free.
  • Carefully pull up on the front of the keyboard to pop it out from the case.
  • Then slide the back out so the keyboard becomes nearly free.
Disconnect the ribbon that is connecting the keyboard to the rest of the computer. Pull the keyboard out and repair or replace as needed. Pull the keyboard out and repair or replace as needed.
  • Disconnect the ribbon that is connecting the keyboard to the rest of the computer.
  • Pull the keyboard out and repair or replace as needed.
Ronan
Membre depuis le 10/10/2011
42 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 6-1, Regan Fall 2011 Membre de l'équipe Cal Poly, Team 6-1, Regan Fall 2011
CPSU-REGAN-F11S6G1
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 476
