Pièces
Aucune pièce nécessaire.
The battery compartment is located in the front-right side of the laptop.
  • The battery compartment is located in the front-right side of the laptop.
Ajouter un commentaire
To insert the battery, gently slide it into the compartment until it clicks in place.
  • To insert the battery, gently slide it into the compartment until it clicks in place.
  • To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
This is not to remove the battery, this is to remove the expansion slot (which has got the floppy disk module in it, in the first picture.
blrutter - Réponse
Sorry I should have mentioned it in my prior comment. The battery has got a release button on it too, but it’s part of the battery, exposed on the front face of the right front corner when the battery is installed.
blrutter - Réponse
With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
  • With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
Carefully pull up on the front of the keyboard to pop it out from the case. Then slide the back out so the keyboard becomes nearly free.
  • Carefully pull up on the front of the keyboard to pop it out from the case.
  • Then slide the back out so the keyboard becomes nearly free.
Disconnect the ribbon that is connecting the keyboard to the rest of the computer. Pull the keyboard out and repair or replace as needed. Pull the keyboard out and repair or replace as needed.
  • Disconnect the ribbon that is connecting the keyboard to the rest of the computer.
  • Pull the keyboard out and repair or replace as needed.
Remove the RAM board located underneath the keyboard by carefully popping it out from its connection. Reinstall or replace as necessary. Remove the RAM board located underneath the keyboard by carefully popping it out from its connection. Reinstall or replace as necessary. Remove the RAM board located underneath the keyboard by carefully popping it out from its connection. Reinstall or replace as necessary.
  • Remove the RAM board located underneath the keyboard by carefully popping it out from its connection. Reinstall or replace as necessary.
Ronan
Membre depuis le 10/10/2011
42 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 6-1, Regan Fall 2011 Membre de l'équipe Cal Poly, Team 6-1, Regan Fall 2011
CPSU-REGAN-F11S6G1
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 622
