Aller au contenu principal
Magic Bullet NutriBullet Base Replacement
Ce dont vous avez besoin
  1. Magic Bullet NutriBullet Base Replacement, Base: étape 1, image 1 de 1
    • Unplug the device from the wall and turn the powerbase upside down.
  2. Magic Bullet NutriBullet Base Replacement: étape 2, image 1 de 2 Magic Bullet NutriBullet Base Replacement: étape 2, image 2 de 2
    • Unscrew the four 10mm screws located on the bottom of the powerbase using the Phillips Head #2 Screwdriver.
  3. Magic Bullet NutriBullet Base Replacement: étape 3, image 1 de 1
    • Once the screws are removed, use slight tension to pull the plastic base up.
    • Make sure the cord does not get caught or frayed by the fan, which is located in the center of the power base.
2 autres ont terminé cette réparation.
Angela Wong
Membre depuis le 01/22/15
1 090 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 19-8, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 19-8, Maness Winter 2015
CPSU-MANESS-W15S19G8
4 membres
10 tutoriels rédigés
3 commentaires
So far it was easy! Yeah!
Elaine - Réponse
With a lot of force can’t get bottom of even 4 screws removed Bullet don’t work anymore may be a piece of junk now
Tommy Simpson - Réponse
Where can you buy the base to replace?
Anne-Christine von Wetter - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 41
Total : 9,502
