Aller au contenu principal
Magna Outreach Rear tire Replacement
Ce dont vous avez besoin
  1. Magna Outreach Rear tire Replacement, Rear Tire: étape 1, image 1 de 1
    • Disconnect the rear brake cable
  2. Magna Outreach Rear tire Replacement: étape 2, image 1 de 1
    • Flip the bike over so that it is resting on the seat and handlebars.
    • Use an adjustable wrench to remove the nuts on both sides of the wheel that hold the wheel to the frame.
    • Lift the tire away from the frame and chain.
  3. Magna Outreach Rear tire Replacement: étape 3, image 1 de 1
    • Insert one tire lever under the tire and hook it onto a spoke. Insert the other tire lever next to the first and slide it along the rim to remove one side of the tire from the rim.
  4. Magna Outreach Rear tire Replacement: étape 4, image 1 de 1
    • Starting at the valve, pull the inner tube out of the gap between the rim and the tire.
  5. Magna Outreach Rear tire Replacement: étape 5, image 1 de 1
    • Pull the tire away from the rim.
West Johnson
Membre depuis le 10/06/14
146 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 1-14, Donnelly Fall 2014 Membre de l'équipe USF Tampa, Team 1-14, Donnelly Fall 2014
USFT-DONNELLY-F14S1G14
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 17
Total : 2,485
