Aller au contenu principal
Magnavox MWD200F Disk Drive Replacement
Ce dont vous avez besoin
  1. Magnavox MWD200F Disk Drive Replacement, Faceplate: étape 1, image 1 de 1
    • Use a Phillips #2 screwdriver to remove the two screws on the top of the device toward the back.
  2. Magnavox MWD200F Disk Drive Replacement: étape 2, image 1 de 1
    • Remove the plastic cover by lifting up the back and pulling it away from the faceplate.
  3. Magnavox MWD200F Disk Drive Replacement: étape 3, image 1 de 1
    • Unclip the three latches on the bottom of the device.
  4. Magnavox MWD200F Disk Drive Replacement: étape 4, image 1 de 1
    • Pull the faceplate off.
  5. Magnavox MWD200F Disk Drive Replacement, Disk Drive: étape 5, image 1 de 2 Magnavox MWD200F Disk Drive Replacement, Disk Drive: étape 5, image 2 de 2
    • Use a Phillips #2 screwdriver to remove the two screws at the base of the disk drive.
  6. Magnavox MWD200F Disk Drive Replacement: étape 6, image 1 de 2 Magnavox MWD200F Disk Drive Replacement: étape 6, image 2 de 2
    • Use the screwdriver to remove two screws on either side of the silver security bar.
  7. Magnavox MWD200F Disk Drive Replacement: étape 7, image 1 de 2 Magnavox MWD200F Disk Drive Replacement: étape 7, image 2 de 2
    • Pull out the silver security bar and set aside.
  8. Magnavox MWD200F Disk Drive Replacement: étape 8, image 1 de 1
    • Take out the two screws on either side of the green circuit board.
  9. Magnavox MWD200F Disk Drive Replacement: étape 9, image 1 de 2 Magnavox MWD200F Disk Drive Replacement: étape 9, image 2 de 2
    • Carefully lift the board just enough to remove the disk drive.
  10. Magnavox MWD200F Disk Drive Replacement: étape 10, image 1 de 3 Magnavox MWD200F Disk Drive Replacement: étape 10, image 2 de 3 Magnavox MWD200F Disk Drive Replacement: étape 10, image 3 de 3
    • Remove the two screws at the back of the disk drive.
  11. Magnavox MWD200F Disk Drive Replacement: étape 11, image 1 de 2 Magnavox MWD200F Disk Drive Replacement: étape 11, image 2 de 2
    • Gently lift the disk drive out of the DVD player.
    • The disk drive is still attached but you are now able to get to underneath it for cleaning and maintenance.
Taryn
Membre depuis le 09/15/11
109 Réputation
4 tutoriels rédigés
Équipe
University of Maine, Team 1-2, Diaz Fall 2011 Membre de l'équipe University of Maine, Team 1-2, Diaz Fall 2011
UMAINE-DIAZ-F11S1G2
2 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 1,489
