Aller au contenu principal
Memorex Mi3X Minimove Back Panel
Ce dont vous avez besoin
  1. Memorex Mi3X Minimove Back Panel, Back Panel: étape 1, image 1 de 1
    • Remove the two plastic screw covers on the back of your Minimove by inserting the flat end of your plastic opening tool between the screw cover and the back panel and prying it out.
    • It may be helpful to pull the plastic covers out with your fingers once the top of the cover has been revealed by using the plastic opening tool.
  2. Memorex Mi3X Minimove Back Panel: étape 2, image 1 de 1
    • This step will require at least a 30 mm Phillips #1 screwdriver.
    • Use a Phillips #1 screwdriver to remove the two 12 mm screws.
  3. Memorex Mi3X Minimove Back Panel: étape 3, image 1 de 1
    • The bottom panel screws and screw covers must be removed in order to access the back panel.
    • Remove the four grey screw covers by inserting the plastic opening tool underneath the screw covers and rotating around the circumference.
    • The adhesive on the screw covers should be sticky enough to put the covers back on when re-assembling the device.
  4. Memorex Mi3X Minimove Back Panel: étape 4, image 1 de 1
    • Remove the two 8 mm screws with a Phillips #1 screwdriver.
    • Remove the two 12 mm screws with a long Phillips #1 screwdriver.
  5. Memorex Mi3X Minimove Back Panel: étape 5, image 1 de 2 Memorex Mi3X Minimove Back Panel: étape 5, image 2 de 2
    • To remove the back panel, use the plastic opening tool and gently work around the outline of the panel. The outline wraps around the sides and can be spotted at the top back of the device.
  6. Memorex Mi3X Minimove Back Panel: étape 6, image 1 de 3 Memorex Mi3X Minimove Back Panel: étape 6, image 2 de 3 Memorex Mi3X Minimove Back Panel: étape 6, image 3 de 3
    • Be careful not to use too much force to remove the panel. The antenna wire is connected to the inside of the panel and may be damaged or ripped off if the panel is not gently removed.
    • After loosening the panel with the plastic opening tool, use moderate force to pry open the panel with your hands.
    • Carefully pull the panel off.
  7. Memorex Mi3X Minimove Back Panel: étape 7, image 1 de 1
    • Use a Phillips #1 screwdriver to detach the wire from the back panel by removing the 8 mm screw connecting the wire to the antenna.
  8. Memorex Mi3X Minimove Back Panel: étape 8, image 1 de 2 Memorex Mi3X Minimove Back Panel: étape 8, image 2 de 2
    • If desired, the antenna can now be removed by pulling inwards and horizontal to the panel bottom.
  9. Memorex Mi3X Minimove Back Panel: étape 9, image 1 de 1
    • Use the Phillips #1 screwdriver to remove the four 12 mm screws.
    • Remove the five 6 mm screws at the top with the same screwdriver.
  10. Memorex Mi3X Minimove Back Panel: étape 10, image 1 de 1
    • Use a Phillips #1 screwdriver and remove the two vertical 8 mm screws from the top.
  11. Memorex Mi3X Minimove Back Panel: étape 11, image 1 de 2 Memorex Mi3X Minimove Back Panel: étape 11, image 2 de 2
    • Pry open the inner back panel by inserting the plastic opening tool in the crack at the top corner.
    • Use moderate force to pry it open and take the cover off.
3 autres ont terminé cette réparation.
Michael Johnson
Membre depuis le 01/31/14
237 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 2-9, Amido Winter 2014 Membre de l'équipe Cal Poly, Team 2-9, Amido Winter 2014
CPSU-AMIDO-W14S2G9
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 640
