Introduction
Do you have a blurry image or a broken outer lens? Follow these step by step instructions to learn how to disassemble the projector and remove the outer lens for your repairs.
Ce dont vous avez besoin
Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
Use the plastic opening tool to gently disengage the black clip housing from the ribbon cable.
Once the ribbon cable is disengaged gently pull the cable off the motherboard.
Unscrew the three 7 mm screws from the motherboard with the Phillips #0 screw driver.
Once loose, lift the motherboard off of the lens casing, and move it away from the workspace.
Unscrew the four 15mm Phillips screws using the Phillips #0 screw driver.
Unscrew the two 12mm Phillips screws using the Phillips #0 screw driver.
Gently remove the entire lens casing from it's position.
Using the plastic opening tool, slightly separate the casing holding the large lens in place.
Separate the casing completely from the inner lens using your hands.
This should release the outer lens and it's immediate casing.
Unscrew the four 8mm Phillips screws at the base of the outer lens casing using the Phillips #0 screw driver.
Separate the white outer casing from the black outer casing.
Using your finger, gently push the lens out of its white encasement.
The outer lens is now free and ready for replacement.
2 autres ont terminé cette réparation.
