Aller au contenu principal
Microsoft Band 2 Battery Replacement
Ce dont vous avez besoin
  1. Microsoft Band 2 Battery Replacement, Battery: étape 1, image 1 de 1
    • Peel back the metal cover on the end of the watchband.
  2. Microsoft Band 2 Battery Replacement: étape 2, image 1 de 1
    • Use a T3 Torx screwdriver to unscrew the four 6 mm screws on the corners of the metal cover plate.
  3. Microsoft Band 2 Battery Replacement: étape 3, image 1 de 1
    • Use the plastic opening tool to pry off the metal cover plate.
  4. Microsoft Band 2 Battery Replacement: étape 4, image 1 de 2 Microsoft Band 2 Battery Replacement: étape 4, image 2 de 2
    • Detach the black ribbon cable by using the tweezers.
  5. Microsoft Band 2 Battery Replacement: étape 5, image 1 de 2 Microsoft Band 2 Battery Replacement: étape 5, image 2 de 2
    • Detach the orange press-fit (or "pop") connector by using the tweezers.
  6. Microsoft Band 2 Battery Replacement: étape 6, image 1 de 2 Microsoft Band 2 Battery Replacement: étape 6, image 2 de 2
    • Pry out the battery using the plastic opening tool.
20 autres ont terminé cette réparation.
Chris Syracuse
Membre depuis le 02/20/17
639 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S1-G5, Leahy Spring 2017 Membre de l'équipe USF Tampa, Team S1-G5, Leahy Spring 2017
USFT-LEAHY-S17S1G5
3 membres
5 tutoriels rédigés
14 commentaires
My Band 2 is not charging and it showing empty battery with AC plugin Icon, but after longtime its not charging . In this case if I replace the battery is it will work or not?
Notes: did not turn on.
Tanvir Ahmed Howlader - Réponse
Microsoft band guide works well - I managed to remove the battery easily - but where do I get a new battery from ?
Margo Bowes - Réponse
TWO WORDS:
THANK YOU!
(A++++)
Somebody know where to buy battery replacement?
I Want Fix IT - Réponse
The only place i found was ebay:
ftlay - Réponse
Batteries can be found on ebay. I was surprised to see the band come back to life. I found the “pop” connector difficult to align properly. Almost lost patience with it. Got it on, reassembled and it powered up.
Dwight Gaut - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 20
Total : 12,836
