Introduction
Use this guide to replace the kickstand for your Surface.
Turn the tablet over so the screen is facing down. Pull up on the bottom corners to open the stand.
  • Turn the tablet over so the screen is facing down.
  • Pull up on the bottom corners to open the stand.
  • Remove the stand by unscrewing the two 5.08mm T5 Torx screws located on the left and right sides.
  • Gently wiggle the stand until the lever in the middle is free, releasing the stand.
Ajouter un commentaire
13 autre(s) ont terminé cette réparation.
Kevin Hua
Membre depuis le 11/01/2013
1 138 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 17-23, Forte Winter 2013 Membre de l'équipe Cal Poly, Team 17-23, Forte Winter 2013
CPSU-FORTE-W13S17G23
5 membres
6 tutoriels rédigés
11 commentaires
Where do you get the replacement kickstand from?
Ray - Réponse
is this compatible with surface pro 1 ?
arqueiro - Réponse
Do you offer a replacement kickstand for the surface rt 2?
allie - Réponse
Does this replacement kickstand come with the screws also?
Andrea Thompson - Réponse
Where can the kickstand screws be purchased separately?
Anthony Welch - Réponse
I am in the uk but there no uk options
we love eletronics - Réponse
Does this work for a broken hinge?
schmee - Réponse
i need to find the torx #5 screws to mount the kickstand. any suggestions?
Harry - Réponse
does this fit on a window 8 pro?
JOHN FAVIS - Réponse
Where can I get the replacement screws from?for surface rt kickstand?
Wishram - Réponse
Voir les statistiques:
Dernières 24 heures : 9
7 derniers jours : 47
30 derniers jours : 265
Total : 30,489
