Aller au contenu principal
Microsoft Surface Laptop 4 (13.5-inch) Feet Replacement
Ce dont vous avez besoin
  1. Microsoft Surface Laptop 4 (13.5-inch) Feet Replacement, Flip the laptop over: étape 1, image 1 de 2 Microsoft Surface Laptop 4 (13.5-inch) Feet Replacement, Flip the laptop over: étape 1, image 2 de 2
    • Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
  2. Microsoft Surface Laptop 4 (13.5-inch) Feet Replacement, Feet removal information: étape 2, image 1 de 3 Microsoft Surface Laptop 4 (13.5-inch) Feet Replacement, Feet removal information: étape 2, image 2 de 3 Microsoft Surface Laptop 4 (13.5-inch) Feet Replacement, Feet removal information: étape 2, image 3 de 3
    • Each foot has a recess to help pry it from the laptop:
    • The back feet recesses are closest to the back edge of the laptop.
    • The front feet recesses are closest to the front edge of the laptop.
  3. Microsoft Surface Laptop 4 (13.5-inch) Feet Replacement, Remove the feet: étape 3, image 1 de 3 Microsoft Surface Laptop 4 (13.5-inch) Feet Replacement, Remove the feet: étape 3, image 2 de 3 Microsoft Surface Laptop 4 (13.5-inch) Feet Replacement, Remove the feet: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    • Insert one arm of your tweezers into the recess of one of the feet.
    • Twist your tweezers and pry up to separate the adhesive and unclip the foot from the laptop.
    • The feet eject very quickly—be careful not to lose them.
    • Remove the foot.
    • Repeat this process on the remaining feet.
  4. Microsoft Surface Laptop 4 (13.5-inch) Feet Replacement, Reassembly information: étape 4, image 1 de 2 Microsoft Surface Laptop 4 (13.5-inch) Feet Replacement, Reassembly information: étape 4, image 2 de 2
    Tesa 61395 Tape
    $5.99
    • This laptop has two different types of feet. During reassembly, make sure the feet go in their correct recesses.
    • The rear feet have a single center clip.
    • The front feet have three clips and can only be reinserted one way.
    • Press the feet into their recesses to secure them to the frame.
    • If the existing feet no longer adhere to the frame, remove the old adhesive and apply a small amount of Tesa Tape where the old adhesive was.
  5. Microsoft Surface Laptop 4 (13.5-inch) Feet Replacement: étape 5, image 1 de 3 Microsoft Surface Laptop 4 (13.5-inch) Feet Replacement: étape 5, image 2 de 3 Microsoft Surface Laptop 4 (13.5-inch) Feet Replacement: étape 5, image 3 de 3
    • If the feet are damaged or worn out, use 8 mm rubber furniture pads:
    • Peel a pad away from its backing.
    • Align the pad over a foot cavity and press down to secure it.
Clay Eickemeyer
Membre depuis le 09/19/22
95 221 Réputation
465 tutoriels rédigés
Équipe
Guide Team Membre de l'équipe Guide Team
Staff
10 membres
15 739 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 23
30 derniers jours : 96
Total : 2,707
