Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Microsoft Surface Pro 7+ Kickstand Replacement
Ce dont vous avez besoin
  1. Microsoft Surface Pro 7+ Kickstand Replacement, Before you begin: étape 1, image 1 de 1
    • Before starting your repair, unplug all cables and fully shut down your Surface Pro.
    Demander à FixBot
    Ajouter un commentaire
  2. Microsoft Surface Pro 7+ Kickstand Replacement, Open the kickstand: étape 2, image 1 de 2 Microsoft Surface Pro 7+ Kickstand Replacement, Open the kickstand: étape 2, image 2 de 2
    • Open the kickstand to about 90 degrees.
    Demander à FixBot
  3. Microsoft Surface Pro 7+ Kickstand Replacement, Remove the kickstand screws: étape 3, image 1 de 3 Microsoft Surface Pro 7+ Kickstand Replacement, Remove the kickstand screws: étape 3, image 2 de 3 Microsoft Surface Pro 7+ Kickstand Replacement, Remove the kickstand screws: étape 3, image 3 de 3
    • While holding the kickstand behind the hinge with your finger, use a Torx Plus 3IP screwdriver to remove the two 2.7 mm‑long screws from each hinge (four total).
    • Make sure the screws don't fall into the hinge cutouts.
    Demander à FixBot
  4. Microsoft Surface Pro 7+ Kickstand Replacement, Lay the kickstand down: étape 4, image 1 de 2 Microsoft Surface Pro 7+ Kickstand Replacement, Lay the kickstand down: étape 4, image 2 de 2
    • Lay the kickstand down towards the top of the device so it's lying flat.
    Demander à FixBot
  5. Microsoft Surface Pro 7+ Kickstand Replacement, Reposition the hinges: étape 5, image 1 de 3 Microsoft Surface Pro 7+ Kickstand Replacement, Reposition the hinges: étape 5, image 2 de 3 Microsoft Surface Pro 7+ Kickstand Replacement, Reposition the hinges: étape 5, image 3 de 3
    • Wrap your finger in a clean cloth and push both hinges down to about 30 degrees.
    Demander à FixBot
  6. Microsoft Surface Pro 7+ Kickstand Replacement, Flip the kickstand over: étape 6, image 1 de 2 Microsoft Surface Pro 7+ Kickstand Replacement, Flip the kickstand over: étape 6, image 2 de 2
    • Flip the kickstand towards the bottom of the device so it's resting on the hinges.
    Demander à FixBot
  7. Microsoft Surface Pro 7+ Kickstand Replacement, Remove the kickstand: étape 7, image 1 de 2 Microsoft Surface Pro 7+ Kickstand Replacement, Remove the kickstand: étape 7, image 2 de 2
    • Firmly secure the device to your work surface with one hand, and use your free hand to pull the kickstand out until both foam tabs slide out.
    • If you're having trouble, make sure the kickstand isn't getting stuck on the hinges—it should slide out fairly easily.
    Demander à FixBot
Spencer Day
Membre depuis le 09/14/22
191 211 Réputation
1 204 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 25
30 derniers jours : 54
Total : 75
