Aller au contenu principal
Microsoft Zune 80 Case Replacement
Ce dont vous avez besoin
  1. Microsoft Zune 80 Case Replacement, Case: étape 1, image 1 de 1
    • Use a metal spudger or Zune opening tool to remove the small silver plastic cap on top of the device.
  2. Microsoft Zune 80 Case Replacement: étape 2, image 1 de 1
    • There are two T3 screws under the cap. Remove both with a T3 screwdriver.
    • Be careful with removing these screws! These screwheads are prone to breaking.
  3. Microsoft Zune 80 Case Replacement, Remove the Casing: étape 3, image 1 de 2 Microsoft Zune 80 Case Replacement, Remove the Casing: étape 3, image 2 de 2
    • Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are 5 clips on each side and two on the bottom.
    • Be careful not to press the tools in too far; there are exposed cables right inside the edge of the device.
turey
Membre depuis le 11/11/09
400 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 6-5, Maness Fall 2009 Membre de l'équipe Cal Poly, Team 6-5, Maness Fall 2009
CPSU-MANESS-F09S6G5
5 membres
5 tutoriels rédigés
Un commentaire
I have followed these steps but im unable to get the back case off, any tips for a stubborn backing?
zippy9765 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 21
Total : 4,728
