Introduction
This guide shows the owner of the scanner how to replace the two bulbs located in the upper lid of the scanner.
Pièces
Aucune pièce nécessaire.
Loosen the screws on the serial port by turning them counter clockwise by hand. After loosening the screws, pull the serial port out. After loosening the screws, pull the serial port out.
  • Loosen the screws on the serial port by turning them counter clockwise by hand.
  • After loosening the screws, pull the serial port out.
Ajouter un commentaire
Lift lid to its vertical position. Pull lid straight up to remove it from the scanner. Pull lid straight up to remove it from the scanner.
  • Lift lid to its vertical position.
  • Pull lid straight up to remove it from the scanner.
Notice that there are two plastic tabs that need to be pushed in to remove the plastic covering. Use tweezers to push these tabs in. Gently pull the plastic covering off of the upper lid.
  • Notice that there are two plastic tabs that need to be pushed in to remove the plastic covering.
  • Use tweezers to push these tabs in.
  • Gently pull the plastic covering off of the upper lid.
Grab the plastic wire housing near the serial port. Gently pull and jiggle the wire housing until it comes free from the circuit board. Gently pull and jiggle the wire housing until it comes free from the circuit board.
  • Grab the plastic wire housing near the serial port.
  • Gently pull and jiggle the wire housing until it comes free from the circuit board.
Gently lift up the bulbs and remove the wires from the plastic. After completely freeing the bulbs, buy new ones and replace.
  • Gently lift up the bulbs and remove the wires from the plastic.
  • After completely freeing the bulbs, buy new ones and replace.
Taylor Nesheim
Membre depuis le 11/10/2011
59 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 6-9, Regan Fall 2011 Membre de l'équipe Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 membres
11 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 987
