Aller au contenu principal
Mitsubishi Diamondpoint NXM76LCD Display Replacement
Ce dont vous avez besoin
  1. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Removing the stand.: étape 1, image 1 de 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Removing the stand.: étape 1, image 2 de 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Removing the stand.: étape 1, image 3 de 3
    • Lift the black cover off.
    • Remove all 4 Phillips #2 screws.
  2. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the 5 screws: étape 2, image 1 de 1
    • Remove the two 24mm Phillips #2 screws.
    • Remove the three 8mm Phillips #2 screws.
  3. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the back panel: étape 3, image 1 de 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the back panel: étape 3, image 2 de 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the back panel: étape 3, image 3 de 3
    • Lift the back and pry the back off.
    • The panel is held in with clips on the side. It needs a lot of force the take it off.
  4. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: étape 4, image 1 de 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: étape 4, image 2 de 2
    • Remove the four 5mm nut screws.
  5. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the 5 screws: étape 5, image 1 de 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the 5 screws: étape 5, image 2 de 2
    • Remove the seven Phillips #1 screws.
  6. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the front panel: étape 6, image 1 de 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the front panel: étape 6, image 2 de 2
    • Remove the three Phillips #2 screws.
    • Remove the two data/power cables.
    • Remove the two speaker cables.
  7. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display cable: étape 7, image 1 de 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display cable: étape 7, image 2 de 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display cable: étape 7, image 3 de 3
    • Pull the two tabs.
    • Pull the connector off.
  8. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the power switch: étape 8, image 1 de 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the power switch: étape 8, image 2 de 2
    • Remove the switch cable off.
    • Remove the two Phillips #2 screws.
  9. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display power: étape 9, image 1 de 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display power: étape 9, image 2 de 2
    • Remove the four display power cables.
    • These cables are interchangeable.
  10. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Lift the display out: étape 10, image 1 de 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Lift the display out: étape 10, image 2 de 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Lift the display out: étape 10, image 3 de 3
    • Lift the display out.
  11. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: étape 11, image 1 de 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: étape 11, image 2 de 2
    • Remove the four Phillips #2 screws.
    • These screws release the display from its enclosure. Hold the screen when removing these screws.
  12. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement: étape 12, image 1 de 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement: étape 12, image 2 de 2
    • Remember to plug in all the cables on the display.
Padraic Hoselton
Membre depuis le 08/22/17
4 180 Réputation
12 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 528 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 3
Total : 152
