Introduction
If your Motorola Moto G4 is no longer charging, replacing the MicroUSB port may be needed. Follow this guide to do the replacement yourself.
Place your thumb in the indent located at bottom left corner of the back cover and pull up to separate. Place your thumb in the indent located at bottom left corner of the back cover and pull up to separate.
  • Place your thumb in the indent located at bottom left corner of the back cover and pull up to separate.
Ajouter un commentaire
Remove the nineteen 3mm screws with a T4 screwdriver. Lift the back panel off. Lift the back panel off.
  • Remove the nineteen 3mm screws with a T4 screwdriver.
  • Lift the back panel off.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Unhook the twisted red and black wire from under the black plastic pieces that are holding it down with a pair of tweezers. Disconnect the wire.
  • Unhook the twisted red and black wire from under the black plastic pieces that are holding it down with a pair of tweezers.
  • Disconnect the wire.
  • Lift the battery out.
  • The battery is glued down so you will have to use some force to pull it out.
  • Be careful not to pull it too hard it could bend the battery.
Use the tweezers, pull up on the clasp that is holding the motherboard down. Use the tweezers, pull up on the clasp that is connecting the motherboard to the headphone jack Use the tweezers, remove the red and black wiring from the bottom of the phone by the charging port
  • Use the tweezers, pull up on the clasp that is holding the motherboard down.
    • Use the tweezers, pull up on the clasp that is connecting the motherboard to the headphone jack
  • Use the tweezers, remove the red and black wiring from the bottom of the phone by the charging port
Use the tweezers pull up on the three corners of the motherboard until it comes out. Use the tweezers pull up on the three corners of the motherboard until it comes out.
  • Use the tweezers pull up on the three corners of the motherboard until it comes out.
The charging port is soldered to the motherboard, to remove desolder and remove port.
  • The charging port is soldered to the motherboard, to remove desolder and remove port.
  • New charging port will have to be soldered back into place.
Giuseppe Spano
Membre depuis le 12/02/2018
89 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S15-G3, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S15-G3, Boczar Spring 2018
USFT-BOCZAR-S18S15G3
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 25
30 derniers jours : 90
Total : 128
