Introduction
Rear camera replacement on the Motorola Moto G4 is a feasible job, and by following this guide you can do it yourself!
Place your thumb in the indent located at bottom left corner of the back cover and pull up to separate. Place your thumb in the indent located at bottom left corner of the back cover and pull up to separate.
  • Place your thumb in the indent located at bottom left corner of the back cover and pull up to separate.
Ajouter un commentaire
Remove the nineteen 3mm screws with a T4 screwdriver. Lift the back panel off. Lift the back panel off.
  • Remove the nineteen 3mm screws with a T4 screwdriver.
  • Lift the back panel off.
Unhook the twisted red and black wire from under the black plastic pieces that are holding it down with a pair of tweezers. Disconnect the wire.
  • Unhook the twisted red and black wire from under the black plastic pieces that are holding it down with a pair of tweezers.
  • Disconnect the wire.
  • Lift the battery out.
  • The battery is glued down so you will have to use some force to pull it out.
  • Be careful not to pull it too hard it could bend the battery.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Use the tweezers, pull up on the clasp that is holding the motherboard down. Use the tweezers, pull up on the clasp that is connecting the motherboard to the headphone jack Use the tweezers, remove the red and black wiring from the bottom of the phone by the charging port
  • Use the tweezers, pull up on the clasp that is holding the motherboard down.
    • Use the tweezers, pull up on the clasp that is connecting the motherboard to the headphone jack
  • Use the tweezers, remove the red and black wiring from the bottom of the phone by the charging port
Use the tweezers pull up on the three corners of the motherboard until it comes out. Use the tweezers pull up on the three corners of the motherboard until it comes out.
  • Use the tweezers pull up on the three corners of the motherboard until it comes out.
Flip motherboard over to access the rear camera.
  • Flip motherboard over to access the rear camera.
  • Peel up orange tape and remove to access the top of rear camera motherboard clamp.
  • Flip up the black tab on the ZIF connector to detach the rear camera.
Remove rear camera from motherboard.
  • Remove rear camera from motherboard.
Separate the black plastic cover from the broken rear camera you removed. Glue black plastic cover onto the new replacement rear camera. Glue black plastic cover onto the new replacement rear camera.
  • Separate the black plastic cover from the broken rear camera you removed.
  • Glue black plastic cover onto the new replacement rear camera.
Nathan Granger
Membre depuis le 12/02/2018
181 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S15-G3, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S15-G3, Boczar Spring 2018
USFT-BOCZAR-S18S15G3
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 28
Total : 72
