Introduction
To remove the speaker you will need to remove the battery, open the phone and remove the motherboard. Be ready to use a plastic opening tool, T5 Torx Screwdriver and a spudger.
Pry the rear cover from the back of the phone.
  • Pry the rear cover from the back of the phone.
Use the word "prying" rather than sliding. We were confused during this step.
Ben Sweeney - Réponse
Insert a spudger or plastic opening tool into the small notch at the base of the battery. Lift the battery out of the phone.
  • Insert a spudger or plastic opening tool into the small notch at the base of the battery.
  • Lift the battery out of the phone.
Ajouter un commentaire
Remove the four 5.0 mm T5 Torx screws from the corners of the phone. Remove three 5.5 mm T5 Torx screws from the back of the phone. Lift up the black rubber flap near the SD card slot.
  • Remove the four 5.0 mm T5 Torx screws from the corners of the phone.
  • Remove three 5.5 mm T5 Torx screws from the back of the phone.
  • Lift up the black rubber flap near the SD card slot.
  • Remove the single 5.5 mm T5 Torx screw beneath the flap.
  • Do not attempt to loosen the screws with too much force. These screws are small, and easily stripped.
Not a phillips head screwdriver. Indicate the appropriate tool.
Hex head screwdriver.
Remove the back case of the phone by gently lifting the tabs located on top of the phone near the lock button. Use the case opener or spudger in these small areas because the plastic tabs can be easily broken.
  • Remove the back case of the phone by gently lifting the tabs located on top of the phone near the lock button.
  • Use the case opener or spudger in these small areas because the plastic tabs can be easily broken.
  • Lift the tabs located on the bottom of the phone to continue removing the back cover.
Red boxes around the tabs so all can be seen clearly. Change the bullet point to red to accommodate said boxes.
rubixtriangle - Réponse
Slide an opening tool between the gap from the back of the case to the front. After separating the sides, make sure there is a noticeable gap between the back case and the rest of the phone.
  • Slide an opening tool between the gap from the back of the case to the front.
  • After separating the sides, make sure there is a noticeable gap between the back case and the rest of the phone.
  • After detaching the tabs and sliding down the sides, there should be a noticeable gap between the front and back cases.
Carefully separate the back case from the rest of the phone by lifting it away from the phone.
  • Carefully separate the back case from the rest of the phone by lifting it away from the phone.
  • Do not completely remove the case from the rest of the phone. The antenna is connected to both cases.
Disconnect the antenna from its housing on the motherboard by gently lifting beneath it.
  • Disconnect the antenna from its housing on the motherboard by gently lifting beneath it.
Specify--lift beneath it near the gold metal piece located on the phone (not the back case)
Ease the antenna from out of its guide along the side of the phone
  • Ease the antenna from out of its guide along the side of the phone
  • Once the antenna is detached, remove the back case and the antenna from the phone
  • The antenna is soldered to the back case. Do not pull with too much force.
Add picture for "easing out of the guide." Also, specify that you must unclip the guide from the phone.
To remove the motherboard, first dislodge the right side of the motherboard, where the external connections are located, from the rest of the phone. This can be done by placing a spudger in between the two ports on the phone, between the black plastic and motherboard, and prying out.
  • To remove the motherboard, first dislodge the right side of the motherboard, where the external connections are located, from the rest of the phone.
  • This can be done by placing a spudger in between the two ports on the phone, between the black plastic and motherboard, and prying out.
  • The motherboard should be able to be easily lifted upwards after dislodging it.
  • If the white rubber piece moves, replace it where it came from upon reassembly.
Specify "right side."
Not clear instructions. Clear/white rubber piece came off during removal--make a note of that possibility.
First, several connections must be disconnected to completely separate the motherboard from the rest of the phone. The connection highlighted with a red box must be pulled down instead of out.
  • First, several connections must be disconnected to completely separate the motherboard from the rest of the phone.
  • The connection highlighted with a red box must be pulled down instead of out.
  • Using the spudger tool, separate the two connections on the motherboard highlighted with orange circles by pulling them out.
  • The black switch on top of this connection acts as a lock. Push it forwards to unlock the connection.
Add color bullets.
After disconnecting the motherboard, there should be five distinct and separate parts of the phone: back cover, back case, front case, battery, and motherboard.
  • After disconnecting the motherboard, there should be five distinct and separate parts of the phone: back cover, back case, front case, battery, and motherboard.
The speaker can be found on the bottom of the inside of the back case and is held in by glue. Use a spudger or case opener tool to pry out the speaker by sliding it in the crack between the two pieces of black plastic.
  • The speaker can be found on the bottom of the inside of the back case and is held in by glue.
  • Use a spudger or case opener tool to pry out the speaker by sliding it in the crack between the two pieces of black plastic.
Where does the bottom speaker makes contact with the logic board?
Paragon - Réponse
2 autre(s) ont terminé cette réparation.
Jake
Membre depuis le 19/04/2012
515 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 9-42, Regan Spring 2012 Membre de l'équipe Cal Poly, Team 9-42, Regan Spring 2012
CPSU-REGAN-S12S9G42
6 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 3,291
