Aller au contenu principal
Motorola C290 Antenna Replacement
  1. Motorola C290 Antenna Replacement, Battery: étape 1, image 1 de 2 Motorola C290 Antenna Replacement, Battery: étape 1, image 2 de 2
    • Position Motorola C290 so that the back of the phone is facing up.
    • Apply pressure to the back cover while simultaneously sliding it downwards.
    • Note: It may be easiest to apply pressure to the ridges at the top of the back cover.
  2. Motorola C290 Antenna Replacement: étape 2, image 1 de 2 Motorola C290 Antenna Replacement: étape 2, image 2 de 2
    • Place your finger in the notch at the top of the battery.
    • Gently lift and pull out battery.
  3. Motorola C290 Antenna Replacement, Antenna: étape 3, image 1 de 3 Motorola C290 Antenna Replacement, Antenna: étape 3, image 2 de 3 Motorola C290 Antenna Replacement, Antenna: étape 3, image 3 de 3
    • Unscrew antenna head from top of phone by twisting counterclockwise.
    • Pull the antenna out through the top hole and set aside.
  4. Motorola C290 Antenna Replacement: étape 4, image 1 de 2 Motorola C290 Antenna Replacement: étape 4, image 2 de 2
    • Remove the plastic tube by lifting the bottom and pulling out towards yourself.
Angelo Ballungay
Membre depuis le 04/15/10
79 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 24-28, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 24-28, Regan Spring 2010
CPSU-REGAN-S10S24G28
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 2
Total : 1,980
