Aller au contenu principal
Motorola C290 Speaker Replacement
Ce dont vous avez besoin
  1. Motorola C290 Speaker Replacement, Outside Case removal: étape 1, image 1 de 3 Motorola C290 Speaker Replacement, Outside Case removal: étape 1, image 2 de 3 Motorola C290 Speaker Replacement, Outside Case removal: étape 1, image 3 de 3
    • Flip open your Motorola C290.
    • Remove rubber stoppers located around main screen using a push pin.
    • This reveals four screws.
    • Use a Torx T6 Screwdriver to unscrew the four screws.
  2. Motorola C290 Speaker Replacement, Removing the front casing: étape 2, image 1 de 2 Motorola C290 Speaker Replacement, Removing the front casing: étape 2, image 2 de 2
    • Use a plastic opening tool to pry open a gap between the top cover and the face of the phone.
    • Slide the plastic opening tool along gap and pry open case.
    • Remove top cover.
  3. Motorola C290 Speaker Replacement, Disconnect the motherboard: étape 3, image 1 de 2 Motorola C290 Speaker Replacement, Disconnect the motherboard: étape 3, image 2 de 2
    • Unclip circuit attachments located on back of screen circuit board using a Spudger.
  4. Motorola C290 Speaker Replacement, Removing the motherboard/screen: étape 4, image 1 de 3 Motorola C290 Speaker Replacement, Removing the motherboard/screen: étape 4, image 2 de 3 Motorola C290 Speaker Replacement, Removing the motherboard/screen: étape 4, image 3 de 3
    • Insert the plastic opening tool between the metal screen components and the plastic frame at the corners.
    • Firmly pry the screen components from the frame with a twisting motion
    • You will need to apply a good amount of force as you pry, twisting in a right-to-left motion.
    • Completely remove screen components from frame.
  5. Motorola C290 Speaker Replacement, Speaker Removal: étape 5, image 1 de 3 Motorola C290 Speaker Replacement, Speaker Removal: étape 5, image 2 de 3 Motorola C290 Speaker Replacement, Speaker Removal: étape 5, image 3 de 3
    • Insert spudger underneath the speaker.
    • Gently break the sticky seal between the phone case and speaker.
    • Lift the speaker off the phone case.
    • Note: It will be necessary to destroy the seal to remove the speaker.
Philip Ybarra
Membre depuis le 04/15/10
27 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 24-28, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 24-28, Regan Spring 2010
CPSU-REGAN-S10S24G28
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 1,166
