Aller au contenu principal
Motorola C350 Upper Speaker Replacement
Ce dont vous avez besoin
  1. Motorola C350 Upper Speaker Replacement, Rear case freeing: étape 1, image 1 de 2 Motorola C350 Upper Speaker Replacement, Rear case freeing: étape 1, image 2 de 2
    • Use your finger to press the button and free the device rear case.
    • You may have to force it a bit more to free its bottom if you open it for the first time.
  2. Motorola C350 Upper Speaker Replacement, Removing battery: étape 2, image 1 de 1
    • slide the black button to free the battery so you can grab it with your other hand.
  3. Motorola C350 Upper Speaker Replacement, Separating the front case: étape 3, image 1 de 2 Motorola C350 Upper Speaker Replacement, Separating the front case: étape 3, image 2 de 2
    • You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
  4. Motorola C350 Upper Speaker Replacement, Logic Board: étape 4, image 1 de 2 Motorola C350 Upper Speaker Replacement, Logic Board: étape 4, image 2 de 2
    • Remove the 4 T6 Torx screws
  5. Motorola C350 Upper Speaker Replacement: étape 5, image 1 de 2 Motorola C350 Upper Speaker Replacement: étape 5, image 2 de 2
    • Use a metal spudger to pell off the four metal clips and separate the motherboard and keyboard from the main plastic part.
  6. Motorola C350 Upper Speaker Replacement: étape 6, image 1 de 1
    • The last thing you need to doto access the Logic Board is to separate the Keyboard/Screen block just taking apart with your fingers.
  7. Motorola C350 Upper Speaker Replacement, Upper Speaker: étape 7, image 1 de 1
    • The upper speaker is kept in place by a metal plate.
    • Use a metal spudger to free the 3 clips on the back side
  8. Motorola C350 Upper Speaker Replacement: étape 8, image 1 de 1
    • Insert your metal spudger to remove the metal plate and free the upper speaker.
Vincent Monteil
Membre depuis le 07/06/13
6 975 Réputation
19 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 451
