Introduction
This guide explains how to replace a damaged or broken camera on the Motorola Cliq. The camera is very fragile, so take care getting it out.
Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off. Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off.
  • Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off.
Ajouter un commentaire
Pinch the battery pull tab located below the camera, pull it upwards, and remove the battery. The pull tab may be tucked under the battery.
  • Pinch the battery pull tab located below the camera, pull it upwards, and remove the battery.
    • The pull tab may be tucked under the battery.
Wedge a plastic opening tool behind the panel covering the camera, pry it up, and remove it using your fingers. The panel is held down by adhesive and may require you to wedge and pry the right side of the panel before it can be easily removed. The panel is held down by adhesive and may require you to wedge and pry the right side of the panel before it can be easily removed.
  • Wedge a plastic opening tool behind the panel covering the camera, pry it up, and remove it using your fingers.
    • The panel is held down by adhesive and may require you to wedge and pry the right side of the panel before it can be easily removed.
Remove the six 4.0 mm T4 Torx screws which line the edge of the back of the phone.
  • Remove the six 4.0 mm T4 Torx screws which line the edge of the back of the phone.
Turn the phone over and slide out the keyboard. Wedge a plastic opening tool where the keyboard meets the back casing of the phone next to the headphone jack. Carefully pry open the back casing along the keyboard's edge until at least two corners of the back casing are separated from the keyboard.
  • Turn the phone over and slide out the keyboard.
  • Wedge a plastic opening tool where the keyboard meets the back casing of the phone next to the headphone jack.
  • Carefully pry open the back casing along the keyboard's edge until at least two corners of the back casing are separated from the keyboard.
    • Do not fully separate the rear panel from the phone. A cable is connecting the two parts together.
Carefully separate the back casing from the rest of the phone.
  • Carefully separate the back casing from the rest of the phone.
Gently pry ZIF connector upwards using the flat end of a spudger tool. The ZIF connector is glued down. Be gentle! Ripping it off or breaking it will make your phone inoperable.
  • Gently pry ZIF connector upwards using the flat end of a spudger tool.
    • The ZIF connector is glued down. Be gentle! Ripping it off or breaking it will make your phone inoperable.
    • You may need adhesive to keep your power cable in place when reassembling your phone.
Press your thumb against the orange power cable and pull it down slowly to disconnect the power cable from the bottom of the keyboard. The rear casing and the rest of the phone should now be completely separated. The rear casing and the rest of the phone should now be completely separated.
  • Press your thumb against the orange power cable and pull it down slowly to disconnect the power cable from the bottom of the keyboard.
  • The rear casing and the rest of the phone should now be completely separated.
Insert a 1.5mm flat head screw in the slit in between the camera housing and the bottom of the camera. Lightly pry upwards and the camera should come loose from the housing. Lightly pry upwards and the camera should come loose from the housing.
  • Insert a 1.5mm flat head screw in the slit in between the camera housing and the bottom of the camera.
  • Lightly pry upwards and the camera should come loose from the housing.
Carefully grab the sides of the camera with your fingers and remove the camera. The foam cover on the top of the camera deforms and tears easily, so handle it with care. The foam cover on the top of the camera deforms and tears easily, so handle it with care.
  • Carefully grab the sides of the camera with your fingers and remove the camera.
    • The foam cover on the top of the camera deforms and tears easily, so handle it with care.
2 autre(s) ont terminé cette réparation.
Tony Tran
Membre depuis le 14/04/2013
64 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 10-42, Amido Spring 2013 Membre de l'équipe Cal Poly, Team 10-42, Amido Spring 2013
CPSU-AMIDO-S13S10G42
4 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 215
