Aller au contenu principal
Motorola Defy Earpiece Speaker Replacement
Ce dont vous avez besoin
  1. Motorola Defy Earpiece Speaker Replacement, Rear Case: étape 1, image 1 de 1
    • Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
  2. Motorola Defy Earpiece Speaker Replacement: étape 2, image 1 de 2 Motorola Defy Earpiece Speaker Replacement: étape 2, image 2 de 2
    • Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
  3. Motorola Defy Earpiece Speaker Replacement, Battery: étape 3, image 1 de 1
    • Use a plastic opening tool to pry the battery out of the phone.
  4. Motorola Defy Earpiece Speaker Replacement, Midframe: étape 4, image 1 de 1
    • Unscrew the two silver screws located at the top of the back of the phone.
  5. Motorola Defy Earpiece Speaker Replacement: étape 5, image 1 de 1
    • Use a plastic opening tool to gently pry the midframe from the rest of the phone.
  6. Motorola Defy Earpiece Speaker Replacement, Motherboard: étape 6, image 1 de 2 Motorola Defy Earpiece Speaker Replacement, Motherboard: étape 6, image 2 de 2
    • Use metal spudger to pry off the middle yellow flap carefully.
  7. Motorola Defy Earpiece Speaker Replacement: étape 7, image 1 de 3 Motorola Defy Earpiece Speaker Replacement: étape 7, image 2 de 3 Motorola Defy Earpiece Speaker Replacement: étape 7, image 3 de 3
    • Use tweezers again to pry off the second yellow flap carefully.
  8. Motorola Defy Earpiece Speaker Replacement: étape 8, image 1 de 1
    • The motherboard is the whole green board. Pry it off carefully with tweezers from the sides and place it aside.
  9. Motorola Defy Earpiece Speaker Replacement, Remove the earpiece speaker: étape 9, image 1 de 2 Motorola Defy Earpiece Speaker Replacement, Remove the earpiece speaker: étape 9, image 2 de 2
    • Once the motherboard is removed, use either the metal tweezers or the metal spudger to remove the speaker by prying it as shown.
    • The speaker is glued to its position, thus you will have to glue the new one back on.
    • The speaker must be pried off carefully. It is very delicate.
Andres
Membre depuis le 10/08/14
101 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 14-2, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 14-2, Leahy Fall 2014
USFT-LEAHY-F14S14G2
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 619
