Pièces
Aucune pièce nécessaire.
Wedge the opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
  • Wedge the opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
Ajouter un commentaire
Once wedged in the opening, slide the plastic opening tool sideways around the sides of the phone.
  • Once wedged in the opening, slide the plastic opening tool sideways around the sides of the phone.
Insert the opening tool in between the battery and the battery holder and wedge the battery out.
  • Insert the opening tool in between the battery and the battery holder and wedge the battery out.
Open the plastic cover with your finger exposing the SD Card
  • Open the plastic cover with your finger exposing the SD Card
  • Use a plastic opening tool to grab the edge of the SD card and pull it straight out.
Use the opening tool to grab the edge of the SD Card and pull it straight out.
  • Use the opening tool to grab the edge of the SD Card and pull it straight out.
Use the T4 torque driver to remove the 6  3mm diameter screws
  • Use the T4 torque driver to remove the 6 3mm diameter screws
Use the opening  tool to pop the volume buttons off
  • Use the opening tool to pop the volume buttons off
Slide the opening tool along the edge wedging the two pieces apart
  • Slide the opening tool along the edge wedging the two pieces apart
  • Caution: Be careful to not to rip the ribbon that is holding the two pieces
Disconnect the ribbon connector, and slide out the screen.
  • Disconnect the ribbon connector, and slide out the screen.
Flip the mother board over and disconnect the ribbon cable connecting the display to the logic board by pulling straight outward with, using the opening tool
  • Flip the mother board over and disconnect the ribbon cable connecting the display to the logic board by pulling straight outward with, using the opening tool
13.    Pull the two halves of the device apart to disconnect the second (wider) ribbon connector.
  • 13. Pull the two halves of the device apart to disconnect the second (wider) ribbon connector.
  • Note: The ribbon connector is bonded to the logic board with adhesive, simply pull it off
Flip the mother board over, and use the opening tool to disconnect the camera from the logic board
  • Flip the mother board over, and use the opening tool to disconnect the camera from the logic board
Mustapha Nadri
Membre depuis le 19/04/2013
1 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 2-22, Maness Spring 2013 Membre de l'équipe Cal Poly, Team 2-22, Maness Spring 2013
CPSU-MANESS-S13S2G22
3 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 751
