Aller au contenu principal
Motorola Droid 2 Speaker Replacement
Ce dont vous avez besoin
  1. Motorola Droid 2 Speaker Replacement, Battery: étape 1, image 1 de 3 Motorola Droid 2 Speaker Replacement, Battery: étape 1, image 2 de 3 Motorola Droid 2 Speaker Replacement, Battery: étape 1, image 3 de 3
    • Slide the battery cover toward the bottom edge of the phone.
    • Remove the battery cover from the rear of the phone.
  2. Motorola Droid 2 Speaker Replacement: étape 2, image 1 de 2 Motorola Droid 2 Speaker Replacement: étape 2, image 2 de 2
    • Lift the battery out of the Droid 2 from the edge closest to the bottom of the phone.
    • Remove the battery from the Droid 2.
  3. Motorola Droid 2 Speaker Replacement, Rear Case: étape 3, image 1 de 2 Motorola Droid 2 Speaker Replacement, Rear Case: étape 3, image 2 de 2
    • Using the tip of a spudger, peel up one corner of the silver ribbon below the battery compartment.
    • Peel the ribbon off the phone.
  4. Motorola Droid 2 Speaker Replacement: étape 4, image 1 de 1
    • Insert the flat end of a spudger and pry the plastic camera cover up off the phone.
    • The thin plastic cover is attached to the phone with an adhesive. Work slowly and carefully.
  5. Motorola Droid 2 Speaker Replacement: étape 5, image 1 de 1
    • Use the tip of a spudger to remove the camera bezel stuck to the rear case.
  6. Motorola Droid 2 Speaker Replacement: étape 6, image 1 de 1
    • Remove the seven 5.5 mm T5 Torx screws securing the rear case to the inner case.
  7. Motorola Droid 2 Speaker Replacement: étape 7, image 1 de 1
    • Insert the flat end of a spudger and pry downwards to release the plastic tab holding the rear case to the motherboard screw.
  8. Motorola Droid 2 Speaker Replacement: étape 8, image 1 de 1
    • Gently insert a spudger between the rear case and front case at the top of the phone, near the audio jack.
    • Carefully pry the top edge of the rear case up from the rest of the phone.
  9. Motorola Droid 2 Speaker Replacement: étape 9, image 1 de 2 Motorola Droid 2 Speaker Replacement: étape 9, image 2 de 2
    • With the spudger still inserted between the rear case and front case, slide the spudger along the right edge of the device, moving toward the bottom, prying as you go.
    • Continue prying along the bottom edge of the device from right to left, freeing it from the front panel.
  10. Motorola Droid 2 Speaker Replacement: étape 10, image 1 de 2 Motorola Droid 2 Speaker Replacement: étape 10, image 2 de 2
    • Continue prying the rear case from the front case along the left side, moving from bottom to top.
    • Lift the rear case up out of the phone.
    • At this point, the button covers on the side of the phone are free and may fall out if you tip the phone upside down.
  11. Motorola Droid 2 Speaker Replacement, Speaker: étape 11, image 1 de 1
    • Carefully lift the speaker/antenna assembly up and out of the phone.
    • If you are re-assembling your phone, insert any power, camera, or volume buttons that may have fallen out at this point.
3 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 12
Total : 6,939
