Introduction
The back case of the Motorola Droid Mini is plastic and can be easily cracked. Replacing this back case is simple and requires only one tool.
Pièces
Aucune pièce nécessaire.
Pull out the volume keys using the plastic opening tool. Pull out the volume keys using the plastic opening tool.
  • Pull out the volume keys using the plastic opening tool.
Ajouter un commentaire
Use the plastic opening tool to gently pry off the back case. Make sure to go around the entire perimeter of the case. Use the plastic opening tool to gently pry off the back case. Make sure to go around the entire perimeter of the case.
  • Use the plastic opening tool to gently pry off the back case. Make sure to go around the entire perimeter of the case.
3 autre(s) ont terminé cette réparation.
Arielle
Membre depuis le 08/10/2014
503 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 9-2, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 9-2, Leahy Fall 2014
USFT-LEAHY-F14S9G2
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 6
Total : 1,761
