Aller au contenu principal
Motorola Droid Turbo Vibrator Replacement
Ce dont vous avez besoin
  1. Motorola Droid Turbo Vibrator Replacement, Rear Case: étape 1, image 1 de 1
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
  2. Motorola Droid Turbo Vibrator Replacement: étape 2, image 1 de 2 Motorola Droid Turbo Vibrator Replacement: étape 2, image 2 de 2
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
  3. Motorola Droid Turbo Vibrator Replacement, Midframe: étape 3, image 1 de 1
    • Remove the midframe bezel.
  4. Motorola Droid Turbo Vibrator Replacement: étape 4, image 1 de 1
    • Remove the four Torx T5 screws securing the midframe plate.
  5. Motorola Droid Turbo Vibrator Replacement: étape 5, image 1 de 1
    • Remove the midframe.
  6. Motorola Droid Turbo Vibrator Replacement, Vibrator: étape 6, image 1 de 2 Motorola Droid Turbo Vibrator Replacement, Vibrator: étape 6, image 2 de 2
    • Use the pointed end of a spudger to gently pry the vibrator up and away from the midframe.
Geoff Wacker
Membre depuis le 09/30/13
89 956 Réputation
89 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 5
Total : 1,203
