Introduction
When the E815 becomes unresponsive, removing and replacing the battery is often the first and best solution.
To replace the battery, you are going to:
  • Remove back cover
  • Remove Battery
  • Replace Battery
Locate the back cover release slide.
  • Locate the back cover release slide.
  • Use your finger to slide it down.
Ajouter un commentaire
Remove the back cover by pulling it away from the phone.
  • Remove the back cover by pulling it away from the phone.
Locate the battery removal slot. Use your finger to pull the battery out from the top.
  • Locate the battery removal slot.
  • Use your finger to pull the battery out from the top.
  • Remove the battery.
2 autre(s) ont terminé cette réparation.
Zoie E
Membre depuis le 12/01/2011
595 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 14-8, Forte Winter 2011 Membre de l'équipe Cal Poly, Team 14-8, Forte Winter 2011
CPSU-FORTE-W11S14G8
5 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 3,143
