Introduction
If the buttons on your Motorola E815 are unresponsive or do not seem as crisp as they used to be, you may need to replace your keypad. To accomplish this, you will
  • Dissemble the phone
  • Access the keypad for repair or replacement
Locate the back cover release slide.
  • Locate the back cover release slide.
  • Use your finger to slide it down.
Ajouter un commentaire
Remove the back cover by pulling it away from the phone.
  • Remove the back cover by pulling it away from the phone.
Locate the battery removal slot. Use your finger to pull the battery out from the top.
  • Locate the battery removal slot.
  • Use your finger to pull the battery out from the top.
  • Remove the battery.
Locate the antenna port on the top of the phone.
  • Locate the antenna port on the top of the phone.
Removing Antenna Only
Zoie E - Réponse
Grip the plastic support post and unscrew the apparatus using a counterclockwise twist. Pull the apparatus up and out of the phone.
  • Grip the plastic support post and unscrew the apparatus using a counterclockwise twist.
  • Pull the apparatus up and out of the phone.
Locate the two screws on the backside of the phone.
  • Locate the two screws on the backside of the phone.
  • Unscrew the two screws using a T6 Screwdriver.
Gently pull the top section of the phone upwards until you feel some resistance. Locate the brown connector that runs from the top section of the phone to the circuit board under the keypad. Using tweezers, gently pry the connector from the circuit board.
  • Gently pull the top section of the phone upwards until you feel some resistance.
  • Locate the brown connector that runs from the top section of the phone to the circuit board under the keypad.
  • Using tweezers, gently pry the connector from the circuit board.
  • Carefully detach the two sections of the phone.
Using the blue pry tool, carefully pull the keypad frame away from the keypad. Gently remove the keypad frame from the keypad. Lift the silicone keypad cover off.
  • Using the blue pry tool, carefully pull the keypad frame away from the keypad.
  • Gently remove the keypad frame from the keypad.
  • Lift the silicone keypad cover off.
Rotate the phone around so that you are looking at the battery cavity. Locate the screws on the bottom base of the phone.
  • Rotate the phone around so that you are looking at the battery cavity.
  • Locate the screws on the bottom base of the phone.
Rotate the phone back to the front side. Slowly lift the bottom portion of the keypad off of the phone until you feel resistance.
  • Rotate the phone back to the front side.
  • Slowly lift the bottom portion of the keypad off of the phone until you feel resistance.
Using tweezers, carefully detach the yellow connector strip from the circuit board by lifting up. Separate the keypad from the circuit board. Separate the keypad from the circuit board.
  • Using tweezers, carefully detach the yellow connector strip from the circuit board by lifting up.
  • Separate the keypad from the circuit board.
Zoie E
Membre depuis le 12/01/2011
595 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 14-8, Forte Winter 2011 Membre de l'équipe Cal Poly, Team 14-8, Forte Winter 2011
CPSU-FORTE-W11S14G8
5 membres
5 tutoriels rédigés
We should have a motherboard replacement.
Santi12008 - Réponse
We need to fullify more this content.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 1,932
