Aller au contenu principal
Motorola Krzr K1m Flex Cable Replacement
Ce dont vous avez besoin
  1. Motorola Krzr K1m Flex Cable Replacement, Battery: étape 1, image 1 de 2 Motorola Krzr K1m Flex Cable Replacement, Battery: étape 1, image 2 de 2
    • Push down on the silver tab located at the top center of the back of the Motorola K1m cellphone.
  2. Motorola Krzr K1m Flex Cable Replacement: étape 2, image 1 de 1
    • While pushing down on the silver tab, slide the back cover towards the silver tab.
    • Remove the back cover.
  3. Motorola Krzr K1m Flex Cable Replacement: étape 3, image 1 de 1
    • Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
    • Replace the old battery with the new battery.
    • Follow all of the steps to remove the battery in reverse order to reassemble.
  4. Motorola Krzr K1m Flex Cable Replacement, Keypad: étape 4, image 1 de 2 Motorola Krzr K1m Flex Cable Replacement, Keypad: étape 4, image 2 de 2
    • Remove the battery with your fingers by pulling the battery from the top corners labeled "Pull Here" located on the left and right side of the top of the battery.
    • Remove the battery.
  5. Motorola Krzr K1m Flex Cable Replacement: étape 5, image 1 de 3 Motorola Krzr K1m Flex Cable Replacement: étape 5, image 2 de 3 Motorola Krzr K1m Flex Cable Replacement: étape 5, image 3 de 3
    Outil utilisé dans cette étape :
    Spudger
    $3.99
    J'achète
    • To begin detaching the battery dock, unscrew the 4 black screws on each corner of the phone with the T5 Torx Screwdriver.
    • Lift up the battery dock where the hinges are located. Carefully insert the T5 Torx Screwdriver in between the battery dock and the back plate of the battery. (See the picture to locate the hinges)
    • Remove the battery dock by popping it up with The Spudger.
  6. Motorola Krzr K1m Flex Cable Replacement: étape 6, image 1 de 3 Motorola Krzr K1m Flex Cable Replacement: étape 6, image 2 de 3 Motorola Krzr K1m Flex Cable Replacement: étape 6, image 3 de 3
    • To remove the chip board, first unplug the flex cable from the logic board with tweezers.
    • Lift up the logic board from the bottom flip with your fingers.
    • Remove the logic board.
  7. Motorola Krzr K1m Flex Cable Replacement: étape 7, image 1 de 2 Motorola Krzr K1m Flex Cable Replacement: étape 7, image 2 de 2
    • Gently pop off the keypad with your fingers.
    • Once the keypad is removed, follow all of the steps in reverse order to replace the old keypad with the new keypad.
  8. Motorola Krzr K1m Flex Cable Replacement, Flex Cable: étape 8, image 1 de 1
    • Remove the small silver screw located where the top of the back of the phone.
  9. Motorola Krzr K1m Flex Cable Replacement: étape 9, image 1 de 1
    • Then take out the small grey plastic cap indicated in the picture.
    • do not lose the cap!
  10. Motorola Krzr K1m Flex Cable Replacement: étape 10, image 1 de 2 Motorola Krzr K1m Flex Cable Replacement: étape 10, image 2 de 2
    • Next, turn the frame on it's side and gently tap it till the hinge cover that was screwed in falls out.
    • Then use your flathead to push here. Be careful! Apply a little force but not too much or else the left hingecover you're pushing out here may shoot out and get lost.
  11. Motorola Krzr K1m Flex Cable Replacement: étape 11, image 1 de 2 Motorola Krzr K1m Flex Cable Replacement: étape 11, image 2 de 2
    • Push in the white thing in the middle, it's spring-loaded, and pull the frame halves apart.
    • DO NOT LOSE THE BLACK HINGE RING. you need it.
  12. Motorola Krzr K1m Flex Cable Replacement: étape 12, image 1 de 2 Motorola Krzr K1m Flex Cable Replacement: étape 12, image 2 de 2
    • Then slide out the flex cable.
    • Slide in the new flex cable the same way you took it out.
    • And congratulations you are done!
Jennifer Hudiono
Membre depuis le 01/13/10
42 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 11-1, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 11-1, Forte Winter 2010
CPSU-FORTE-W10S11G1
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 10,497
