Aller au contenu principal
Motorola Krzr K1m LCD Replacement
Ce dont vous avez besoin
  1. Motorola Krzr K1m LCD Replacement, LCD: étape 1, image 1 de 2 Motorola Krzr K1m LCD Replacement, LCD: étape 1, image 2 de 2
    Outil utilisé dans cette étape :
    Spudger
    $3.99
    J'achète
    • Begin by removing the trim piece from around the front face plate.
    • Be very careful when dealing with the trim. It is very delicate, so be cautious when approching this next part.
    • Using your fingers or The Spudger get underneath the trim. Start by applying enough force to pry the trim off.
    • Be patient when trying to pry off the trim. The tape attaching the trim to the phone is very strong. Just be persistent and patient and it will eventually give.
    • Remove the trim piece.
  2. Motorola Krzr K1m LCD Replacement: étape 2, image 1 de 2 Motorola Krzr K1m LCD Replacement: étape 2, image 2 de 2
    • Once you have removed the trim you will see 4 gold screws at the corners of the phone. Using a T5 Torx Screwdriver, remove the screws.
  3. Motorola Krzr K1m LCD Replacement: étape 3, image 1 de 2 Motorola Krzr K1m LCD Replacement: étape 3, image 2 de 2
    Spudger
    $3.99
    J'achète
    • Gently use The Spudger towards the edge of the phone and lift the face plate off.
    • The touch-sensitive keys and chip board/LCD screen (which is green) may remain attached to the face plate because of the glue.
    • Gently hold the green logic board down as you lift the face plate apart from it.
    • Remove the face plate.
  4. Motorola Krzr K1m LCD Replacement: étape 4, image 1 de 3 Motorola Krzr K1m LCD Replacement: étape 4, image 2 de 3 Motorola Krzr K1m LCD Replacement: étape 4, image 3 de 3
    • Gently, with your fingers or a tweezer, lift the orange flex cable apart from the pin connector it is connected to.
    • Gently remove the green logic board/LCD (Liquid Crystal Display) screen away from the phone.
    • Replace with new green logic board/LCD screen.
    • To reassemble the phone, follow of the steps in reverse order.
2 autres ont terminé cette réparation.
Jennifer Hudiono
Membre depuis le 01/13/10
42 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 11-1, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 11-1, Forte Winter 2010
CPSU-FORTE-W10S11G1
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 6,548
