Introduction
This guide is helpful for users who are having difficulty with sound quality, clarity, or volume while taking a phone call.
Insert the spudger into the notch on the corner of the phone and lift up to remove the back case. Insert the spudger into the notch on the corner of the phone and lift up to remove the back case.
  • Insert the spudger into the notch on the corner of the phone and lift up to remove the back case.
Ajouter un commentaire
Use the T4 Torx Screwdriver to remove the 17 3.2 mm screws in the back panel covering the battery.
  • Use the T4 Torx Screwdriver to remove the 17 3.2 mm screws in the back panel covering the battery.
Lift up and remove the back panel. Lift up and remove the back panel. Lift up and remove the back panel.
  • Lift up and remove the back panel.
After removing the back panel, use the             spudger to lift and detach the Battery Flux Cable from the Motherboard. After removing the back panel, use the             spudger to lift and detach the Battery Flux Cable from the Motherboard.
  • After removing the back panel, use the spudger to lift and detach the Battery Flux Cable from the Motherboard.
Wedge the spudger between the battery and the phone to lift the battery up and remove the battery. There will be slight resistance to this but the battery will not be damaged by this. It is just the adhesive tape. Wedge the spudger between the battery and the phone to lift the battery up and remove the battery. There will be slight resistance to this but the battery will not be damaged by this. It is just the adhesive tape. Wedge the spudger between the battery and the phone to lift the battery up and remove the battery. There will be slight resistance to this but the battery will not be damaged by this. It is just the adhesive tape.
  • Wedge the spudger between the battery and the phone to lift the battery up and remove the battery. There will be slight resistance to this but the battery will not be damaged by this. It is just the adhesive tape.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Use the Spudger to lift up and detach the Back Facing Camera from the Motherboard. Use the Spudger to lift up and detach the Back Facing Camera from the Motherboard.
  • Use the Spudger to lift up and detach the Back Facing Camera from the Motherboard.
Use the Precision Tweezers to remove the camera from the phone. Use the Precision Tweezers to remove the camera from the phone.
  • Use the Precision Tweezers to remove the camera from the phone.
Use the T4 Torx Screwdriver to remove the 2 3.2 mm screws circled in the image.
  • Use the T4 Torx Screwdriver to remove the 2 3.2 mm screws circled in the image.
Use the Spudger to lift up and detach the Main Flex Cable from the Motherboard. Use the Spudger to lift up and detach the Main Flex Cable from the Motherboard.
  • Use the Spudger to lift up and detach the Main Flex Cable from the Motherboard.
Use the Spudger to lift up and detach the LCD Screen Flex Cable from the Motherboard. Use the Spudger to lift up and detach the LCD Screen Flex Cable from the Motherboard.
  • Use the Spudger to lift up and detach the LCD Screen Flex Cable from the Motherboard.
Use the Plastic Spudger to lift up and detach the Signal Flex Cable from the Motherboard. The Signal Flex Cable should still be attached to the body of the phone.
  • Use the Plastic Spudger to lift up and detach the Signal Flex Cable from the Motherboard. The Signal Flex Cable should still be attached to the body of the phone.
Use the Spudger to lift up and remove the Motherboard from the phone. Use the Spudger to lift up and remove the Motherboard from the phone.
  • Use the Spudger to lift up and remove the Motherboard from the phone.
Use the Plastic Spudger to remove the Earpiece Speaker from the phone. Use the Plastic Spudger to remove the Earpiece Speaker from the phone. Use the Plastic Spudger to remove the Earpiece Speaker from the phone.
  • Use the Plastic Spudger to remove the Earpiece Speaker from the phone.
Jack Haseman
Membre depuis le 19/03/2018
645 Réputation
6 tutoriels rédigés
Équipe
Baylor, Team S3-G2, Williams Spring 2018 Membre de l'équipe Baylor, Team S3-G2, Williams Spring 2018
BU-WILLIAMS-S18S3G2
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 26
Total : 43
