Introduction
This guide will show you step-by-step how to replace the back casing.
Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
  • Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
  • Be careful not to poke yourself when handling the push pin because it is very sharp.
Ajouter un commentaire
Use the T6 screwdriver to remove the four screws holding the casing together.
  • Use the T6 screwdriver to remove the four screws holding the casing together.
  • Note: they are in the same place where you removed the four rubber coverings
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful. Note: the phone should be face up and the plastic opening tool should be face downwards
  • Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful.
  • Note: the phone should be face up and the plastic opening tool should be face downwards
  • Once you get the plastic opening tool in, slide it across the side of the phone, making sure to keep the plastic opening tool wedged in between the two casings.
  • Repeat the 3 steps above for the top, bottom, and opposite side.
Gently lift and remove the back casing. Gently lift and remove the back casing.
  • Gently lift and remove the back casing.
Luis Herrera
Membre depuis le 21/01/2010
52 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 16-33, Maness Winter 2010 Membre de l'équipe Cal Poly, Team 16-33, Maness Winter 2010
CPSU-MANESS-W10S16G33
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 2
Total : 4,999
