Introduction
If you are having issues with the Moto Z2's battery, use this guide to replace it.
Place the phone on a flat surface with the screen facing up.
  • Place the phone on a flat surface with the screen facing up.
  • Insert the flat end of a nylon spudger into the crease separating the screen and the body in the lower right corner of the phone.
  • Pry open part of the screen by pulling the tool and the screen toward you.
  • You may be required to use a heating element, such as the iOpener, to heat and loosen the adhesive underneath before attempting to pry it open.
Ajouter un commentaire
Wedge the plastic opening tool between the gap created by separating the screen and body of the phone in the right hand corner to hold it open. Insert the nylon spudger into the lower left corner of the screen and pry the screen toward you. Continue to insert the plastic opening and spudger tools around the phone, and pry open the screen until it is fully separated from the device.
  • Wedge the plastic opening tool between the gap created by separating the screen and body of the phone in the right hand corner to hold it open.
  • Insert the nylon spudger into the lower left corner of the screen and pry the screen toward you.
  • Continue to insert the plastic opening and spudger tools around the phone, and pry open the screen until it is fully separated from the device.
  • Remove the screen gently and slowly as the screen may crack otherwise.
Remove the screen by pulling from right to left and placing the screen face down on the flat surface next to the main body of the device. Remove the screen by pulling from right to left and placing the screen face down on the flat surface next to the main body of the device.
  • Remove the screen by pulling from right to left and placing the screen face down on the flat surface next to the main body of the device.
Using the flat end of the nylon spudger, pull off the black tape on top of the screen connector piece that the black ribbon is attached to. Using the flat end of the nylon spudger, pull off the black tape on top of the screen connector piece that the black ribbon is attached to.
  • Using the flat end of the nylon spudger, pull off the black tape on top of the screen connector piece that the black ribbon is attached to.
Insert the black spudger under the lock of the latch connecting the black ribbon of the screen to the phone body. Pull up on the lock to unlock the latch.
  • Insert the black spudger under the lock of the latch connecting the black ribbon of the screen to the phone body.
  • Pull up on the lock to unlock the latch.
  • Separate the black ribbon from the latch by pulling gently to the left.
Kits de RAM Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits de RAM Mac
Obtenez plus de mémoire sur votre Mac.
Unscrew the two 3mm T4 screws from the speaker. Unscrew the two 3mm T4 screws from the speaker. Unscrew the two 3mm T4 screws from the speaker.
  • Unscrew the two 3mm T4 screws from the speaker.
Use the nylon spudger to lift and remove the speaker from the phone chassis. Use the nylon spudger to lift and remove the speaker from the phone chassis. Use the nylon spudger to lift and remove the speaker from the phone chassis.
  • Use the nylon spudger to lift and remove the speaker from the phone chassis.
Insert the flat end of the nylon spudger on the side of the camera closest to the battery. Pry up the camera by pushing down on the spudger until the camera pops up.
  • Insert the flat end of the nylon spudger on the side of the camera closest to the battery.
  • Pry up the camera by pushing down on the spudger until the camera pops up.
Insert the flat end of the nylon spudger underneath the black lock. Unlock the ribbon cable by pulling up on the lock with the nylon spudger.
  • Insert the flat end of the nylon spudger underneath the black lock.
  • Unlock the ribbon cable by pulling up on the lock with the nylon spudger.
  • Separate the camera from the board by pulling gently towards the bottom of the phone.
Wedge the plastic opening tool underneath the motherboard near the battery and use the flat end of the spudger to create a gap. Gradually make this gap bigger so that  the area is still loose when you remove the spudger. You may want to use a thinner prying tool instead of the plastic opening tool  to make this step easier.
  • Wedge the plastic opening tool underneath the motherboard near the battery and use the flat end of the spudger to create a gap.
  • Gradually make this gap bigger so that the area is still loose when you remove the spudger.
  • You may want to use a thinner prying tool instead of the plastic opening tool to make this step easier.
Loosen the motherboard in the area between the camera and battery by gently wedging the flat end of the spudger to create a gap such that the area is loose when the spudger is removed.
  • Loosen the motherboard in the area between the camera and battery by gently wedging the flat end of the spudger to create a gap such that the area is loose when the spudger is removed.
Insert the flat end of the nylon spudger underneath the edge of the phone near the camera. Gently pry the motherboard from the phone until it is raised enough to put a finger between it and the phone. With your fingers, gently pry the rest of the motherboard up from the phone.
  • Insert the flat end of the nylon spudger underneath the edge of the phone near the camera.
  • Gently pry the motherboard from the phone until it is raised enough to put a finger between it and the phone.
  • With your fingers, gently pry the rest of the motherboard up from the phone.
  • When using your fingers to remove the motherboard completely, be extremely careful, as you can easily break the motherboard.
After you have removed the motherboard, only the battery should remain on the device's body.
  • After you have removed the motherboard, only the battery should remain on the device's body.
  • Remove the battery.
Reesa John
Membre depuis le 24/01/2018
181 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S2-G1, Livingston Winter 2018 Membre de l'équipe Cal Poly, Team S2-G1, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G1
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 8
7 derniers jours : 60
30 derniers jours : 313
Total : 766
