Aller au contenu principal
Motorola Moto Z3 Battery Replacement
Ce dont vous avez besoin
  1. Motorola Moto Z3 Battery Replacement, Heat the display: étape 1, image 1 de 1
    • Power your phone off before you begin.
    • If possible, drain the battery before disassembly. When the battery is charged, there's increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
    • If your display is cracked, completely cover it with packing tape to contain the glass shards and avoid injury.
    • Prepare an iOpener and heat the front of the phone along its right edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the display.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Motorola Moto Z3 Battery Replacement, Display adhesive and cutting reference: étape 2, image 1 de 2 Motorola Moto Z3 Battery Replacement, Display adhesive and cutting reference: étape 2, image 2 de 2
    • In the following steps, you will separate the display assembly from the Moto Z3's chassis.
    • The first image shows the back of the display assembly after it has been removed from the phone. The second image shows the front of the phone to reference where the display cable lies.
    • If you plan to re-use the display assembly, pay particular attention to the side edges. When slicing through the glue in this area, you must be careful to insert your tool less than 2 mm, or your tool will come in contact with the LCD and damage it.
    • Take special care when cutting near the display cable. If you pry too deep or too forcefully, it is very easy to damage the cable. If you encounter extra resistance around this area, do not try to force the pick forward. Pull it out and reinsert it on the other side of the display cable before you continue cutting.
    • Playing cards are a safer, but much slower, prying tool. The soft paper cards are less likely to damage the LCD, which is good news if you plan to reuse it.
  3. Motorola Moto Z3 Battery Replacement, Cut the display adhesive: étape 3, image 1 de 3 Motorola Moto Z3 Battery Replacement, Cut the display adhesive: étape 3, image 2 de 3 Motorola Moto Z3 Battery Replacement, Cut the display adhesive: étape 3, image 3 de 3
    • Apply a suction cup to the display, near the middle of the right edge.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the display and rear case.
    • If the screen is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • This may require a significant amount of force, but you only need to open a very slight gap with the suction cup to insert your tool.
    • If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools quickly, so you may need to heat it repeatedly.
    • Insert an opening pick (or playing card) into the gap you opened behind the display.
    • Do not insert the tool more than 1.5 mm past the edge of the display.
  4. Motorola Moto Z3 Battery Replacement: étape 4, image 1 de 3 Motorola Moto Z3 Battery Replacement: étape 4, image 2 de 3 Motorola Moto Z3 Battery Replacement: étape 4, image 3 de 3
    • Slide the tool all along the right edge of the phone to slice through the adhesive securing the display.
    • If you plan to reuse the display, continue moving the tool in a straight line as you approach the corners of the phone—do not round the corners with the tool. The corners of the LCD come very close to the edge of the digitizer and are easy to damage.
  5. Motorola Moto Z3 Battery Replacement: étape 5, image 1 de 1
    • Heat the upper edge of the display to soften the adhesive underneath.
  6. Motorola Moto Z3 Battery Replacement: étape 6, image 1 de 3 Motorola Moto Z3 Battery Replacement: étape 6, image 2 de 3 Motorola Moto Z3 Battery Replacement: étape 6, image 3 de 3
    • Slide your tool underneath the top bezel to separate the glue.
    • You can insert the pick slightly deeper here, but if you want to re-use the display, don't insert the tool more than 5.5 mm past the edge of the display.
  7. Motorola Moto Z3 Battery Replacement: étape 7, image 1 de 1
    • Heat the left edge of the phone to soften the adhesive securing the left edge of the display.
  8. Motorola Moto Z3 Battery Replacement: étape 8, image 1 de 3 Motorola Moto Z3 Battery Replacement: étape 8, image 2 de 3 Motorola Moto Z3 Battery Replacement: étape 8, image 3 de 3
    • Slide your tool along the left edge of the phone to separate the glue securing the display.
    • Be very careful when slicing near the bottom of the phone to avoid damaging the display cable. Refer to step two for help identifying and avoiding the display cable.
  9. Motorola Moto Z3 Battery Replacement: étape 9, image 1 de 1
    • Heat the bottom edge of the phone to soften the adhesive securing the bottom of the display.
  10. Motorola Moto Z3 Battery Replacement: étape 10, image 1 de 3 Motorola Moto Z3 Battery Replacement: étape 10, image 2 de 3 Motorola Moto Z3 Battery Replacement: étape 10, image 3 de 3
    • Slice through the glue under the lower bezel.
    • You can insert the pick slightly deeper here, but if you want to re-use the display, don't insert the tool more than 4 mm past the edge of the display.
  11. Motorola Moto Z3 Battery Replacement, Remove the display: étape 11, image 1 de 1
    • If the display remains stuck, re-heat and slice the adhesive repeatedly as needed.
    • Lift the display from the right edge and swing it open, away from the phone. The display is still attached to the phone chassis at the lower left edge, so do not fully remove it yet.
    • When you lift the display, two small plastic gaskets—one for the front-facing camera, and one for the front-facing sensors—may fall out of the phone. Keep track of these gaskets and make sure to reinstall them before sealing the phone.
  12. Motorola Moto Z3 Battery Replacement: étape 12, image 1 de 3 Motorola Moto Z3 Battery Replacement: étape 12, image 2 de 3 Motorola Moto Z3 Battery Replacement: étape 12, image 3 de 3
    • While holding the display open, use tweezers to remove the tape over the display cable connector.
    • Use the point of a spudger to pry up the locking tab on the display cable's ZIF connector.
  13. Motorola Moto Z3 Battery Replacement: étape 13, image 1 de 1
  14. Motorola Moto Z3 Battery Replacement, Remove the tape: étape 14, image 1 de 1
    • Use tweezers to peel up the black tape over the battery connector off of the battery.
    • If possible, avoid damaging the tape so that it can be reused.
  15. Motorola Moto Z3 Battery Replacement, Disconnect the battery: étape 15, image 1 de 2 Motorola Moto Z3 Battery Replacement, Disconnect the battery: étape 15, image 2 de 2
    • Use the point of a spudger to pry the battery connector straight up and disconnect it.
  16. Motorola Moto Z3 Battery Replacement, Remove the tape: étape 16, image 1 de 1
    • Use tweezers to peel up and remove the black tape at the bottom of the battery.
  17. Motorola Moto Z3 Battery Replacement, Remove the earpiece speaker and front sensor assembly: étape 17, image 1 de 1
    • Remove six 3.4 mm-long T3 Torx screws.
    • There may be tape covering the screws in the top corners. If this is the case, carefully peel the tape back to access the screws, and replace it during reassembly.
  18. Motorola Moto Z3 Battery Replacement: étape 18, image 1 de 2 Motorola Moto Z3 Battery Replacement: étape 18, image 2 de 2
    • Insert the point of a spudger into the small rectangular opening on the right edge of the earpiece speaker and sensor assembly.
    • Use the spudger to pry the assembly up and release the clips securing it to the phone chassis.
  19. Motorola Moto Z3 Battery Replacement: étape 19, image 1 de 1
    • Remove the earpiece speaker and sensor assembly.
    • The earpiece speaker connector sits under the assembly and will disconnect as you lift the assembly. During reassembly, make sure to reconnect this connector.
  20. Motorola Moto Z3 Battery Replacement, Disconnect the fingerprint sensor: étape 20, image 1 de 3 Motorola Moto Z3 Battery Replacement, Disconnect the fingerprint sensor: étape 20, image 2 de 3 Motorola Moto Z3 Battery Replacement, Disconnect the fingerprint sensor: étape 20, image 3 de 3
    • Use the flat end of a spudger to lift the fingerprint sensor connector straight up and out of its socket.
    • Use tweezers to gently bend the cable toward the edge of the phone to move it out of the way.
  21. Motorola Moto Z3 Battery Replacement, Remove the battery: étape 21, image 1 de 1
    • Apply a freshly heated iOpener to the back of the phone directly behind the battery for two minutes to help soften the adhesive securing the battery.
    • Re-heat and reapply the iOpener as necessary.
    • Alternatively, apply high-concentration (>90%) isopropyl alcohol under the edge of the battery to weaken the adhesive underneath. Let the phone sit for several minutes to allow the alcohol to penetrate and weaken the adhesive.
  22. Motorola Moto Z3 Battery Replacement: étape 22, image 1 de 2 Motorola Moto Z3 Battery Replacement: étape 22, image 2 de 2
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    J'achète
    • Insert an opening pick or a plastic card along the edge of the battery.
    • Apply steady, even pressure to slowly lever the battery up and out of the phone.
    • If necessary, use several rounds of heating or alcohol and pressure to slowly weaken the adhesive, and the battery will begin to separate.
    • Try your best not to deform the battery during this process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
  23. Motorola Moto Z3 Battery Replacement: étape 23, image 1 de 2 Motorola Moto Z3 Battery Replacement: étape 23, image 2 de 2
    Tesa 61395 Tape
    $5.99
    J'achète
    • Continue pulling up the battery until all the adhesive releases from the rear case.
    • Remove the battery.
    • Do not reuse the battery after it has been removed. The stress of removal can cause hidden damage to the battery cell, creating a potential safety hazard. Replace it with a new battery.
    • Before installing your new battery, peel up all the old adhesive and remove it from the phone.
    • For best results, clean the area underneath the battery with isopropyl alcohol and a lint-free cloth or coffee filter. This helps prep the surface so the new battery can adhere more strongly. When reassembling your phone, replace old adhesive with stretch release adhesive strips, double-sided tape, or pre-cut adhesive strips.
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
12 autres ont terminé cette réparation.
Adam O'Camb
Membre depuis le 04/11/15
196 299 Réputation
416 tutoriels rédigés
3 commentaires
how do you reconnect the earpiece speaker connector after adding the new battery? it is under the speaker assembly and i can’t seem to get the connector to line up.
Philip Gwinnell - Réponse
I found to add pressure in that area and you should hear the ZIF pop into place
obsurd hotdog -
This guide doesnt cover a single bit of reassembly regarding the adhesive placements etc. some might be obvious but some arent quite so just saying “follow the disassembly steps in reverse” is not adequate here.
Chris Dormady - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 22
30 derniers jours : 100
Total : 12,162
