Aller au contenu principal
Motorola Q Global Speakers Replacement
Ce dont vous avez besoin
  1. Motorola Q Global Speakers Replacement, Battery: étape 1, image 1 de 1
    • Turn the phone face down.
    • Press and hold the release button in the middle of the back panel.
    • Slide the bottom panel down to remove.
  2. Motorola Q Global Speakers Replacement: étape 2, image 1 de 2 Motorola Q Global Speakers Replacement: étape 2, image 2 de 2
    • Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
    • When reinserting the battery, make sure the contacts in the battery are lined up with the contacts in the phone.
  3. Motorola Q Global Speakers Replacement, Speakers: étape 3, image 1 de 1
    • Press inwardly on the upper casing until it pops out of the phone.
  4. Motorola Q Global Speakers Replacement: étape 4, image 1 de 1
    • Slide the upper case rightward and lift up.
    • Lift the camera sticker so that it does not get damaged.
  5. Motorola Q Global Speakers Replacement: étape 5, image 1 de 2 Motorola Q Global Speakers Replacement: étape 5, image 2 de 2
    • Remove the six labeled screws with a T5 torx screw driver.
  6. Motorola Q Global Speakers Replacement: étape 6, image 1 de 1
    • Once the screws are removed, use the plastic opening tool to remove the black casing.
  7. Motorola Q Global Speakers Replacement: étape 7, image 1 de 1
    • Remove the speakers by using the plastic remover tool.
  8. Motorola Q Global Speakers Replacement: étape 8, image 1 de 1
    • Insert the new speakers by gently pressing them down into place.
Carlos De La Parra
Membre depuis le 10/05/12
14 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 6-31, Regan Fall 2012 Membre de l'équipe Cal Poly, Team 6-31, Regan Fall 2012
CPSU-REGAN-F12S6G31
5 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 13
Total : 635
