Aller au contenu principal
Motorola Q700 Sidekick Speaker and Camera Replacement
Ce dont vous avez besoin
  1. Motorola Q700 Sidekick Speaker and Camera Replacement, Phone: étape 1, image 1 de 1
    • When looking at the front of the phone, use the Plastic Opening Tool to pry off the four buttons located in each of the corners on the front.
  2. Motorola Q700 Sidekick Speaker and Camera Replacement: étape 2, image 1 de 1
    • Turn the phone face-down. Remove the back cover, exposing the battery.
    • Use the Plastic Opening Tool to pry the battery out of the phone.
  3. Motorola Q700 Sidekick Speaker and Camera Replacement: étape 3, image 1 de 1
    • Using the appropriate size Phillips screwdriver, unscrew the four screws located in each of the corners on the back of the device.
    • Although the battery is shown in this picture, please remember to make sure that it is removed in order to proceed with disassembly.
  4. Motorola Q700 Sidekick Speaker and Camera Replacement: étape 4, image 1 de 1
    • After removal of the back screws, use the Plastic Opening Tool to carefully separate the top and bottom halves of the device.
  5. Motorola Q700 Sidekick Speaker and Camera Replacement: étape 5, image 1 de 1
    • Using the appropriate size Phillips screwdriver, remove any screws that are attached or associated with the keypad and carefully remove keypad from the device.
  6. Motorola Q700 Sidekick Speaker and Camera Replacement: étape 6, image 1 de 1
    • On the back of the device, you will see individual green and yellow technical pieces. Remove those two pieces from the phone with your fingers and set aside.
  7. Motorola Q700 Sidekick Speaker and Camera Replacement: étape 7, image 1 de 1
    • You should now have all of the pieces separated and disassembled for your device.
  8. Motorola Q700 Sidekick Speaker and Camera Replacement, Speaker and Camera: étape 8, image 1 de 1
    • complete dissassembly as instructed by guide
  9. Motorola Q700 Sidekick Speaker and Camera Replacement: étape 9, image 1 de 1
    • Remove camera piece from casing
  10. Motorola Q700 Sidekick Speaker and Camera Replacement: étape 10, image 1 de 1
    • replace with new camera piece into casing and reassemble by reversing dissemble procedure
Rich
Membre depuis le 04/08/13
125 Réputation
6 tutoriels rédigés
Équipe
SUNY Cortland, Team 1-4, Getto Spring 2013 Membre de l'équipe SUNY Cortland, Team 1-4, Getto Spring 2013
SUNYCORT-GETTO-S13S1G4
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 203
