Aller au contenu principal
Motorola RAZR V3i Battery Replacement
Ce dont vous avez besoin
  1. Motorola RAZR V3i Battery Replacement, Battery: étape 1, image 1 de 1
    • Make sure the phone is turned off by holding down the red End Call/Power button until the phone shuts off.
    • If you have a phone case, it has to be removed.
  2. Motorola RAZR V3i Battery Replacement: étape 2, image 1 de 3 Motorola RAZR V3i Battery Replacement: étape 2, image 2 de 3 Motorola RAZR V3i Battery Replacement: étape 2, image 3 de 3
    • Close the phone and find the battery cover button, located on the backside of the phone underneath the hinge.
    • Using your finger, press down on the button to release the back cover. Then, lift the cover and remove it from the phone completely.
    • The flat edge of a credit card or other flat object will also work.
  3. Motorola RAZR V3i Battery Replacement: étape 3, image 1 de 3 Motorola RAZR V3i Battery Replacement: étape 3, image 2 de 3 Motorola RAZR V3i Battery Replacement: étape 3, image 3 de 3
    • Remove the battery by pushing down on it from the top while gently pulling it outwards.
    • Be careful not to use too much force as the battery retaining tab could be damaged.
Ligne d'arrivée
5 autres ont terminé cette réparation.
Nigel
Membre depuis le 09/06/11
133 Réputation
2 tutoriels rédigés
Équipe
Cuesta, Team 1-5, Zipperian Fall 2011 Membre de l'équipe Cuesta, Team 1-5, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G5
1 membre
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 57
Total : 7,183
