Introduction
The purpose of this guide is to show how to install or replace a Motorola V3c battery.
Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c. Lift and remove the rear panel away from the V3c. Lift and remove the rear panel away from the V3c.
  • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
  • Lift and remove the rear panel away from the V3c.
With the phone closed, press the silver button shown with a fingernail or such. Tilt and lift the battery cover and put aside.
walltoall - Réponse
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Remove the battery by pushing in the top of the battery and lifting it away from the phone. Remove the battery by pushing in the top of the battery and lifting it away from the phone.
  • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
The Motorola V3 battery has a notch in one corner to ensure it can only go in one way. Fit the replacement battery by offering its bottom edge to the device, then tilt and click using thumb pressure.
walltoall - Réponse
4 autre(s) ont terminé cette réparation.
krisko
Membre depuis le 14/01/2010
95 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 11-4, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 membres
8 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 5,609
