Introduction
This guide will show you how to remove and replace the screen for a Motorola V3c.
Pièces
Aucune pièce nécessaire.
Remove the four rubber pieces from all corners of the area that borders the screen.
  • Remove the four rubber pieces from all corners of the area that borders the screen.
Ajouter un commentaire
Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
  • Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
  • Be sure that you do not strip or damage the screws.
Carefully pry the screen away from the phone using a plastic spudger.
  • Carefully pry the screen away from the phone using a plastic spudger.
  • Pry slowly, as too much bending will crack the screen. There are also two fragile ribbon cables that connect the screen and camera to the phone.
Take the screen housing off of the casing. Watch for small pieces falling out of the screen during this step. Keep track of these pieces. Watch for small pieces falling out of the screen during this step. Keep track of these pieces.
  • Take the screen housing off of the casing.
  • Watch for small pieces falling out of the screen during this step. Keep track of these pieces.
Pry screen cover off with plastic spudger. The screen cover has some adhesive holding it to the screen
  • Pry screen cover off with plastic spudger.
  • The screen cover has some adhesive holding it to the screen
Remove small black sticker covering the camera ribbon connector.
  • Remove small black sticker covering the camera ribbon connector.
Flip over small hinge that covers the camera ribbon connection.
  • Flip over small hinge that covers the camera ribbon connection.
Pull off the rubber camera cover and camera. The camera and camera cover may come off either separately or together. The camera and camera cover may come off either separately or together.
  • Pull off the rubber camera cover and camera.
  • The camera and camera cover may come off either separately or together.
Disconnect the metallic ribbon cover.
  • Disconnect the metallic ribbon cover.
Remove and replace the screen. Remove and replace the screen.
  • Remove and replace the screen.
Ligne d'arrivée
Joshua Ruehlig
Membre depuis le 14/01/2010
503 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 11-4, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 membres
8 tutoriels rédigés
Is it a T5 or a T4 for removing the screws?
Francis Reyes - Réponse
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 8
30 derniers jours : 15
Total : 8,913
