Aller au contenu principal
Motorola Razr V3c Upper Casing (CDMA) Replacement
Ce dont vous avez besoin
  1. Motorola Razr V3c Upper Casing (CDMA) Replacement, Upper Casing (CDMA): étape 1, image 1 de 1
    • Remove the four rubber pieces from all corners of the area around the screen.
  2. Motorola Razr V3c Upper Casing (CDMA) Replacement: étape 2, image 1 de 1
    • Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
    • Be sure that you do not strip or damage the screws.
  3. Motorola Razr V3c Upper Casing (CDMA) Replacement: étape 3, image 1 de 1
    • Carefully pry the screen away from the phone using a plastic spudger.
    • Pry slowly, as too much bending will crack the screen. There are also two fragile ribbon cables that connect the screen and camera to the phone.
  4. Motorola Razr V3c Upper Casing (CDMA) Replacement: étape 4, image 1 de 3 Motorola Razr V3c Upper Casing (CDMA) Replacement: étape 4, image 2 de 3 Motorola Razr V3c Upper Casing (CDMA) Replacement: étape 4, image 3 de 3
    • Take the screen housing off of the casing.
    • Watch for small pieces falling out of the screen during this step. Keep track of these pieces.
4 autres ont terminé cette réparation.
krisko
Membre depuis le 01/14/10
104 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 11-4, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 5,204
