Introduction
The outer housing can be removed to be cleaned or swapped to a custom housing.
Pièces
Aucune pièce nécessaire.
Remove the rearmost panel by pushing down on the silver button, then simultaneously pulling downward on the panel. Lift the panel off of the phone. Lift the panel off of the phone.
  • Remove the rearmost panel by pushing down on the silver button, then simultaneously pulling downward on the panel.
  • Lift the panel off of the phone.
Ajouter un commentaire
Using your thumbnail or a thin flat head screwdriver, peel back the screen protector on the inside of the phone: It is only held on by glue but may take a good amount of force to be removed. Using your thumbnail or a thin flat head screwdriver, peel back the screen protector on the inside of the phone: It is only held on by glue but may take a good amount of force to be removed. Using your thumbnail or a thin flat head screwdriver, peel back the screen protector on the inside of the phone: It is only held on by glue but may take a good amount of force to be removed.
  • Using your thumbnail or a thin flat head screwdriver, peel back the screen protector on the inside of the phone: It is only held on by glue but may take a good amount of force to be removed.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Unscrew the four screws using the T6 Torx Screwdriver. Unscrew the four screws using the T6 Torx Screwdriver.
  • Unscrew the four screws using the T6 Torx Screwdriver.
Peel back the screen protector frame. Close phone at the hinge, then pull off the front outer casing. Peel back the screen protector frame. Close phone at the hinge, then pull off the front outer casing. Peel back the screen protector frame. Close phone at the hinge, then pull off the front outer casing.
  • Peel back the screen protector frame. Close phone at the hinge, then pull off the front outer casing.
Minh Tran
Membre depuis le 15/01/2010
2 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 4-15, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 4-15, Forte Winter 2010
CPSU-FORTE-W10S4G15
5 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 2,025
