Introduction
As this replacement guide works on an internal component of the Xoom Wifi, completion of prior steps to remove external parts is necessary.
There are two 6.6mm screws that hold ports into place as well as the back panel. Remove these with a T-5 Torx screwdriver. There are two 6.6mm screws that hold ports into place as well as the back panel. Remove these with a T-5 Torx screwdriver.
  • There are two 6.6mm screws that hold ports into place as well as the back panel. Remove these with a T-5 Torx screwdriver.
Ajouter un commentaire
Apply light pressure with hand and slide the back plate till it stops in this position. There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
  • Apply light pressure with hand and slide the back plate till it stops in this position.
  • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
  • As soon as the clips are released the back should slide off.
Remove last two 4.2mm screws from the remaining back piece with a T-5 Torx screwdriver. Once both screws are taken out, lift the rest of the backing out of the way. Once both screws are taken out, lift the rest of the backing out of the way.
  • Remove last two 4.2mm screws from the remaining back piece with a T-5 Torx screwdriver.
  • Once both screws are taken out, lift the rest of the backing out of the way.
Use a spudger or a fine tip to lift the black tab to a vertical position. A spudger is needed to remove the plastic border around the camera.
  • Use a spudger or a fine tip to lift the black tab to a vertical position.
  • A spudger is needed to remove the plastic border around the camera.
When lifting the camera out, be sure to pull the orange ribbon cable as well. When lifting the camera out, be sure to pull the orange ribbon cable as well.
  • When lifting the camera out, be sure to pull the orange ribbon cable as well.
2 autre(s) ont terminé cette réparation.
Andrew Mercier
Membre depuis le 14/04/2014
487 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 3-39, Maness Spring 2014 Membre de l'équipe Cal Poly, Team 3-39, Maness Spring 2014
CPSU-MANESS-S14S3G39
4 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 271
