Aller au contenu principal
Motorola i710 Keypad Sensor Replacement
  1. Motorola i710 Keypad Sensor Replacement, Battery Cover: étape 1, image 1 de 2 Motorola i710 Keypad Sensor Replacement, Battery Cover: étape 1, image 2 de 2
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
  2. Motorola i710 Keypad Sensor Replacement, Battery: étape 2, image 1 de 1
    • Push the battery towards the top of the phone and lift up.
  3. Motorola i710 Keypad Sensor Replacement, Motherboard: étape 3, image 1 de 3 Motorola i710 Keypad Sensor Replacement, Motherboard: étape 3, image 2 de 3 Motorola i710 Keypad Sensor Replacement, Motherboard: étape 3, image 3 de 3
    • Lift the motherboard away from the case of the phone, being careful not to break the wire that goes up into the hinge.
    • Peel the motherboard off of the keypad. The two pieces are glued together and separate without much effort.
    • The motherboard should now be completely disconnected from the phone.
  4. Motorola i710 Keypad Sensor Replacement, Keypad Sensor: étape 4, image 1 de 2 Motorola i710 Keypad Sensor Replacement, Keypad Sensor: étape 4, image 2 de 2
    • Once the motherboard has been removed from the keypad, the keypad sensor can be detached from the phone at the hinge.
    • Gently pry off the cable connecting the keypad sensor. The keypad sensor should now be completely separated from the phone.
Katelyn
Membre depuis le 10/22/12
1 Réputation
2 tutoriels rédigés
Équipe
Clemson, Team 14-2, Benson Fall 2012 Membre de l'équipe Clemson, Team 14-2, Benson Fall 2012
CLEM-BENSON-F12S14G2
4 membres
17 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 14
Total : 310
