Aller au contenu principal
Motorola i710 LCD Screen Replacement
Ce dont vous avez besoin
  1. Motorola i710 LCD Screen Replacement, Battery Cover: étape 1, image 1 de 2 Motorola i710 LCD Screen Replacement, Battery Cover: étape 1, image 2 de 2
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
  2. Motorola i710 LCD Screen Replacement, Battery: étape 2, image 1 de 1
    • Push the battery towards the top of the phone and lift up.
  3. Motorola i710 LCD Screen Replacement, LCD Screen Cover: étape 3, image 1 de 3 Motorola i710 LCD Screen Replacement, LCD Screen Cover: étape 3, image 2 de 3 Motorola i710 LCD Screen Replacement, LCD Screen Cover: étape 3, image 3 de 3
    • Although the lower half of the phone in these images has been disassembled, it is not necessary for removing the LCD screen.
    • With the help of plastic opening tools, remove the i710 name plate and Motorola logo from the backside of the phone.
    • The four screws holding the upper half of the phone together should now be visible.
  4. Motorola i710 LCD Screen Replacement: étape 4, image 1 de 2 Motorola i710 LCD Screen Replacement: étape 4, image 2 de 2
    • With a H1.5 screwdriver, unscrew the four H1.5 sized screws from the back of the phone.
    • Flip the phone onto its back and, with the help of a plastic opening tool, remove the metal speaker cover that is above the LCD screen.
  5. Motorola i710 LCD Screen Replacement: étape 5, image 1 de 3 Motorola i710 LCD Screen Replacement: étape 5, image 2 de 3 Motorola i710 LCD Screen Replacement: étape 5, image 3 de 3
    • Slide a plastic opening tool along the edge of the LCD Screen Cover to separate the cover from the phone casing. Apply a small amount of force towards the cover if necessary.
    • The LCD screen should now be completely separated from the phone.
  6. Motorola i710 LCD Screen Replacement, LCD Screen: étape 6, image 1 de 3 Motorola i710 LCD Screen Replacement, LCD Screen: étape 6, image 2 de 3 Motorola i710 LCD Screen Replacement, LCD Screen: étape 6, image 3 de 3
    • Use a spudger to detach the ribbon cable connecting the the LCD Screen to the rest of the phone.
    • The LCD Scren will now lift out from the phone casing.
    • Be careful not to break the speaker's ribbon cable that sits behind the LCD Screen.
Carson Meena
Membre depuis le 10/22/12
16 Réputation
5 tutoriels rédigés
Équipe
Clemson, Team 14-2, Benson Fall 2012 Membre de l'équipe Clemson, Team 14-2, Benson Fall 2012
CLEM-BENSON-F12S14G2
4 membres
17 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 400
