Aller au contenu principal
Motorola i850 Speaker Replacement
Ce dont vous avez besoin
  1. Motorola i850 Speaker Replacement, LCD Board: étape 1, image 1 de 1
    • Open the flip cover of the phone with the LCD screen facing towards you.
  2. Motorola i850 Speaker Replacement: étape 2, image 1 de 2 Motorola i850 Speaker Replacement: étape 2, image 2 de 2
    • Use a Razor Blade to remove the screw covers.
    • Razor Blade is very sharp. Use caution.
  3. Motorola i850 Speaker Replacement: étape 3, image 1 de 1
    • Unscrew the screws using a Phillips #00 Screwdriver.
  4. Motorola i850 Speaker Replacement: étape 4, image 1 de 1
    • Insert a Spudger into the side crack of the flip cover and slowly separate the phone cover from the case.
  5. Motorola i850 Speaker Replacement: étape 5, image 1 de 1
    • Gently separate the flip cover case from the phone with your hands when the crack is wide enough.
  6. Motorola i850 Speaker Replacement: étape 6, image 1 de 1
    • Partially close the flip cover of the phone in order to take off the outer case.
  7. Motorola i850 Speaker Replacement: étape 7, image 1 de 1
    • Completely remove the outer casing from the phone.
  8. Motorola i850 Speaker Replacement: étape 8, image 1 de 2 Motorola i850 Speaker Replacement: étape 8, image 2 de 2
    • Place your thumb underneath the protective metal covering to remove it from the phone.
  9. Motorola i850 Speaker Replacement: étape 9, image 1 de 1
    • Gently detach the black microchip from the phone with a Tweezer.
  10. Motorola i850 Speaker Replacement: étape 10, image 1 de 1
    • Prop out the LCD board from the phone using your fingertips.
  11. Motorola i850 Speaker Replacement: étape 11, image 1 de 2 Motorola i850 Speaker Replacement: étape 11, image 2 de 2
    • Remove the LCD board from the phone by grabbing the bottom side of the LCD board.
  12. Motorola i850 Speaker Replacement, Speaker: étape 12, image 1 de 1
    • Use a flathead screwdriver to gently remove the speaker.
  13. Motorola i850 Speaker Replacement: étape 13, image 1 de 1
    • Insert the new speaker into the phone and it should look like the image at left.
Kevin Dermody
Membre depuis le 04/08/10
1 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 34-56, Forte Spring 2010 Membre de l'équipe Cal Poly, Team 34-56, Forte Spring 2010
CPSU-FORTE-S10S34G56
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 1,144
