Aller au contenu principal
Mr. Coffee DW13 O Ring Replacement
Ce dont vous avez besoin
  1. Mr. Coffee DW13 O Ring Replacement, Base: étape 1, image 1 de 2 Mr. Coffee DW13 O Ring Replacement, Base: étape 1, image 2 de 2
    • Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean.
    • Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
  2. Mr. Coffee DW13 O Ring Replacement: étape 2, image 1 de 2 Mr. Coffee DW13 O Ring Replacement: étape 2, image 2 de 2
    • Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
  3. Mr. Coffee DW13 O Ring Replacement: étape 3, image 1 de 1
    • Gently lift the base cover to expose the inside of the coffee machine.
  4. Mr. Coffee DW13 O Ring Replacement, O Ring: étape 4, image 1 de 2 Mr. Coffee DW13 O Ring Replacement, O Ring: étape 4, image 2 de 2
    • Remove the two 13mm screws securing the silver support bracket using a #2 Phillips head screwdriver.
  5. Mr. Coffee DW13 O Ring Replacement: étape 5, image 1 de 1
    • Gently lift the silver support bracket freeing the heating plate from the heating coil.
  6. Mr. Coffee DW13 O Ring Replacement: étape 6, image 1 de 2 Mr. Coffee DW13 O Ring Replacement: étape 6, image 2 de 2
    • Use needle-nose pilers to pinch and loosen the crimps
  7. Mr. Coffee DW13 O Ring Replacement: étape 7, image 1 de 1
    • Once the crimps are loosened, slide them down the tubing.
  8. Mr. Coffee DW13 O Ring Replacement: étape 8, image 1 de 2 Mr. Coffee DW13 O Ring Replacement: étape 8, image 2 de 2
    • Separate the tubing from the heating coil by grasping the tubing in one hand and the heating coil in the other and gently pulling apart.
  9. Mr. Coffee DW13 O Ring Replacement: étape 9, image 1 de 2 Mr. Coffee DW13 O Ring Replacement: étape 9, image 2 de 2
    • Place one of your hands on the front side of the heating plate.
    • Use this hand to gently push the heating plate towards yourself and out of the machine.
  10. Mr. Coffee DW13 O Ring Replacement: étape 10, image 1 de 2 Mr. Coffee DW13 O Ring Replacement: étape 10, image 2 de 2
    Outil utilisé dans cette étape :
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    J'achète
3 autres ont terminé cette réparation.
Madeline Landis
Membre depuis le 01/21/14
137 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 10-31, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 10-31, Maness Winter 2014
CPSU-MANESS-W14S10G31
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 15
Total : 1,031
