Aller au contenu principal
Mr. Coffee DW13 Power Cord Replacement
Ce dont vous avez besoin
  1. Mr. Coffee DW13 Power Cord Replacement, Base: étape 1, image 1 de 2 Mr. Coffee DW13 Power Cord Replacement, Base: étape 1, image 2 de 2
    • Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean.
    • Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
  2. Mr. Coffee DW13 Power Cord Replacement: étape 2, image 1 de 2 Mr. Coffee DW13 Power Cord Replacement: étape 2, image 2 de 2
    • Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
  3. Mr. Coffee DW13 Power Cord Replacement: étape 3, image 1 de 1
    • Gently lift the base cover to expose the inside of the coffee machine.
  4. Mr. Coffee DW13 Power Cord Replacement, Power Cord: étape 4, image 1 de 2 Mr. Coffee DW13 Power Cord Replacement, Power Cord: étape 4, image 2 de 2
    • Locate the white tab that covers and holds the power cord in place. It has two screws on either side of it.
    • Use a #2 Philips Head screwdriver to unscrew the two 13mm screws holding the tab in place.
  5. Mr. Coffee DW13 Power Cord Replacement: étape 5, image 1 de 2 Mr. Coffee DW13 Power Cord Replacement: étape 5, image 2 de 2
    • Gently lift up on the white tab, removing it from the coffee machine.
  6. Mr. Coffee DW13 Power Cord Replacement: étape 6, image 1 de 2 Mr. Coffee DW13 Power Cord Replacement: étape 6, image 2 de 2
    • Locate the 2 electrical connectors running from the black plastic-coated power cord to the interior of the power switch.
    • One cord is copper colored and ends at the power switch in a silver metal square.
    • The other cord is white and ends at the power switch in a black plastic square.
  7. Mr. Coffee DW13 Power Cord Replacement: étape 7, image 1 de 2 Mr. Coffee DW13 Power Cord Replacement: étape 7, image 2 de 2
    • Grasp the copper cord close to the power switch. Lightly pull the silver end tab from the end to detach it.
  8. Mr. Coffee DW13 Power Cord Replacement: étape 8, image 1 de 2 Mr. Coffee DW13 Power Cord Replacement: étape 8, image 2 de 2
    • Lightly pull the white cord away from the power switch by grasping the black plastic-coated head.
    • There are two white cords attached to each other. Pull them apart by grasping the different black heads and separating them.
  9. Mr. Coffee DW13 Power Cord Replacement: étape 9, image 1 de 3 Mr. Coffee DW13 Power Cord Replacement: étape 9, image 2 de 3 Mr. Coffee DW13 Power Cord Replacement: étape 9, image 3 de 3
    • Pull the power cord through the hole at the back of the base of the machine, followed by the two colored cords.
3 autres ont terminé cette réparation.
Tess Bradley
Membre depuis le 01/26/14
373 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 10-31, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 10-31, Maness Winter 2014
CPSU-MANESS-W14S10G31
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 22
Total : 3,172
