Introduction
The bottom cover must be removed prior to replacing or repairing any internal parts of the Mr. Coffee TF6 (hot plate, power cord, and water tubes). In the event that the bottom cover breaks or must be replaced, a replacement cover must by obtained from the manufacturer.
Pièces
Aucune pièce nécessaire.
Facing the bottom of the TF6, carefully pull the two rubber feet out with your hands.
  • Facing the bottom of the TF6, carefully pull the two rubber feet out with your hands.
Ajouter un commentaire
Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place. Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place.
  • Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place.
Gently lift the bottom cover, detaching it from the main body of the TF6.
  • Gently lift the bottom cover, detaching it from the main body of the TF6.
Johnny Romeka
Membre depuis le 24/01/2014
201 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 13-18, Regan Winter 2014 Membre de l'équipe Cal Poly, Team 13-18, Regan Winter 2014
CPSU-REGAN-W14S13G18
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 342
