Aller au contenu principal
Mr. Coffee TF6 Dust Cover Replacement
Ce dont vous avez besoin
  1. Mr. Coffee TF6 Dust Cover Replacement, Dust Cover: étape 1, image 1 de 2 Mr. Coffee TF6 Dust Cover Replacement, Dust Cover: étape 1, image 2 de 2
    • Facing the front of the TF6, gently lift the dust cover along its hinge until it reaches its designed stopping point.
  2. Mr. Coffee TF6 Dust Cover Replacement: étape 2, image 1 de 2 Mr. Coffee TF6 Dust Cover Replacement: étape 2, image 2 de 2
    • Orient the retaining bracket upwards (away from the main body of unit).
    • Do not push the retaining bracket beyond its designed range of motion. It may snap if too much force is applied outside its limit.
  3. Mr. Coffee TF6 Dust Cover Replacement: étape 3, image 1 de 1
    • With the retaining clip in its released position, pull the spout down towards the filter basket.
  4. Mr. Coffee TF6 Dust Cover Replacement: étape 4, image 1 de 2 Mr. Coffee TF6 Dust Cover Replacement: étape 4, image 2 de 2
    • Carefully detach the dust cover by disengaging the locking pins, starting at one side.
    • Extra force may be required to disengage the dust cover's locking pins. Refrain from applying excessive upward force on the dust cover, as dong so may cause the pins to snap under pressure.
Follow these steps in reverse order with a new Dust Cover.
Jordan
Membre depuis le 01/31/14
204 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 13-18, Regan Winter 2014 Membre de l'équipe Cal Poly, Team 13-18, Regan Winter 2014
CPSU-REGAN-W14S13G18
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 2
Total : 383
